Join propane cylinder with black pipe?
What are some of the ways to join a horizontal 20 pound propane cylinder with 3/4 inch black pipe?
I would like to use some sort of flexible line, perhaps rubber, so I can unhook the cylinder and remove from the bus easily.
Perhaps I am wrong, but I have concerns about having the correct diameter line to supply the system without starting off with a choke point and not being able to supply the genset properly.
Although I can fit the pipe, I know nothing about plumbing propane. Any tips about parts, fittings and hose I might need would be greatly appreciated. Are there any books around about plumbing RV's generally?
As I mentioned, I have plumbed the propane system using 3/4 inch black pipe. This system totals about 12 feet in length and feeds a one-two burner propane stove top, an Ecotemp hot water heater, a Mr Heater propane heater and a dual fuel (gas and propane) 5000 Watt, 10 HP, genset. The genset is at the end of the 12 feet.
Thanks in advance for the tips
