Old 01-18-2019, 12:00 PM   #1
Engine: Cat C7
Mini Split While Driving
Pardon me if this has been covered, but I've read and read and not seen (or comprehended) the answer.
I'm about to gut my bus and want to ditch the two rear air conditioners and passenger heater. If I install a mini split (which would run on a genny while parked), can I run it while driving? I'm sort of picturing it wired to an inverter, fed by a battery bank, which would be receiving power from the alternator while driving.
Is this feasible?
Joe
TeacherJoe is online now   Reply With Quote
Old 01-18-2019, 12:20 PM   #2
Hey Joe,
You should be able to run it while driving.
The challenge is that your bus "road" A/C is likely 50k-80k Btu. Your mini-splits are likely 9k-12k Btu.
Heating and cooling loads are much greater while driving than when parked.
I removed the road air from my first bus and installed two 12k Btu A/C's. Big mistake. Two 12k Btu A/C's were terribly ineffective when I was driving in the Southwest in the summertime.
Both A/C's running full blast. Wearing just a pair of shorts and having sweat running down like crazy.
My recommendation: keep the road A/C and avoid TX, NM and AZ in the Summer.....
Old 01-18-2019, 12:30 PM   #3
General consensus has been that running AC like that is ineffective who traveling down the road.
Old 01-18-2019, 12:43 PM   #4
Engine: Cat C7
Iíll mention this is a shorty. Living space is 105 square feet.
Joe
Old 01-18-2019, 01:30 PM   #5
Hey Joe,
Aye its real hard to cool a bus going down the road. Christopher can tell you more than anyone about AC!
Roll Your Own Build Thread
Old 01-18-2019, 06:07 PM   #6
Ninjakitty's Avatar
Engine: 6.6 New Holland Dies
Rated Cap: 60 kids, 10 window
Is this feasible?
Joe
To answer your question, yes, you can run while driving. Will it cool like the factory a/c, not as likely. Mounting the air handler above the driver's seat with some extra 12 volt fans blowing would probably be your best location.
I run mine off of an inverter and battery bank
Nick
Old 01-19-2019, 02:00 AM   #7
Chassis: e450 super duty
Engine: 7.3l ford powerstroke
I would not recomend it. you can possibly do some damage to your compressor. Condensing units need a solid stable ground while running. To much vibration can throw the balance off the scroll..
Blue Sky's
dopamine16 is offline   Reply With Quote
Old 01-19-2019, 08:47 AM   #8
its pretty well covered.. as for damage.. thus far i dotn think anyone has damaged them.. i know david ran his going down the road all summer.. it wasnt cold in his bus but the units didnt get damaged..
im always a propnent of either a specially built A/C that can alter its capacity like Joeblack is doing.. (running his bus A/C off of a pony engine.. he can vary the capacity by varying fan speeds and engine speeds).. or have a separate road A/C and parked A/C..
minisplits are an excellent choice for parked A/C in my opinion. buy a bus with dashboard A/C for keeping the driver seat cool in summer..
my red bus has factory A/C as a hanging unit in the rear.. i completely went through that system and it gives me about 37-40 degree air even on the hottest days and im somewhat comfortable up front in the driver seat.. (its a 50k system supposedly)..
in my DEV bus I installed custom dash air.. and even before i fixed the fubar-ed factory floors.. having the cold air dash vents blowing on my kept me pretty decent on all but the hottest days.. that dahs unit is 25k.. and the rear unit right behind it is 40k.
Old 01-19-2019, 09:40 AM   #9
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Like Christopher said, I ran mine all summer on the road. The only problems that I had were that it didnít cool the cabin very well and that I had a flare nut loosen enough through vibration that I lost enough of my charge to render the unit unusable.
Iíve since recharged the system and after tightening the loose flare nut I found have had no problems.
In my experience, with the oem fans running, it would cool the driver decently well mounted above the windshield, but the rest of the family was miserable.
The master bedroom also could cool well since it is such a small number of cubic feet: 7íx7.5íx4í. With the curtain to the rest of the bus closed it can cool or heat quickly in pretty much any situation.
The very front and very back of the bus were the places to be!
I donít have the tome and money to try to do more with over the road AC ATM, but have realized that up to the mid 90ís opening the windows is honestly the best method for keeping the whole bus comfortable in the heat.
If you have factory cabin air that works, I would think hard about keeping it. It is very expensive to replace and hard to substitute for.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 01-19-2019, 10:57 AM   #10
the big thing to remember is that a full size conventional bus... 11 windows with a dognose that has factory or dealer imstalled Air-conditioning will have roughly 120,000 BTU.. thats close to 10 TONS! in fixed-A/C terms.. now granted during conversion you are insulating and removing or covering windows, etc.. however you are not going t oget it down to where a simple 12k or 24k BTU is going to cool it... your personal car factory air is usually 12,000 at least...
the consensus on this form seems to be people love to remove "those ugly units".. and its really a personal preference.. my own ideas is why soend all this time money and effort building such a nice RV that you dont even have the simplest of features in which is A/C..
as david mentioned, adding it is expensive and takes a lot of effort.. ive done it.. more than once.. and will be building a completely retro-looking system for my 40 year old restoration bus.. but its getting easier and easier to find busses that have factory A/C.. when you find one... treat it like a unicorn and enjoy being nice n cool on the highway.. and install mini splits so you can enjoy being nice N cool after you get off the road..
front engine busses give you lots of heat.. windows down in a bus at 85 degrees outside driving into the sun is a **LOT** different than windows down at 85 in your car... frankly i love being warm.. ikm the guy that sits outside in florida in the summertime working on my computer till it dies of heat.. but I will say its miserable at those temps in a bus on the highway without air-conditioning..
Rear engine bus you are a bit better off as you arent bombarded by engine heat.. but you still have the large windshield to overcome the sunload..
