Old 06-12-2012, 01:25 PM   #11
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Modified sine wave for a fridge?
This is similar to both that I have, If you have the height I would recommend one with a separate freezer. In my opinion the freezer works much
better if it's a separate unit.Amps is what I said in previous post.
http://www.bestbuy.com/site/Frigidai...&skuId=9723536
Old 06-12-2012, 02:02 PM   #12
Diesel Dan's Avatar
Engine: DT466/AT545
I've been agonizing over that decision for some time now. The ones you describe are all about 3ft tall, and I need to squeeze whatever fridge I get into a 31" high space under my counter or face the prospect of tearing apart all my cabinetry in that part of the bus and rebuilding for the larger fridge. This was one area I did not plan out very well. I guess I was planning on using coolers but then changed my mind. Anyways, I think I'm going to just settle for the smaller fridge with built in freezer compartment for now and see how that goes.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-12-2012, 02:20 PM   #13
this is what I am planning with a thermostate added,do you really need a freezer?
http://www.walmart.com/ip/Black-Deck...White/16681003
with something like this
http://www.amazon.com/Johnson-Contro...rds=thermostat
maybe mount it on slids?
Old 06-12-2012, 09:53 PM   #14
Coachwork: Ward
Chassis: Crane Carrier
We had no luck burned up our 1st 18 cf "soft star" fridge so our current build we are going to use one of these as the fridge is the only AC device other than the 12v converter... New fridge is 16cf soft start....
It's a gamble but still cheaper then a Xantrex
http://www.ebay.com/itm/Ramsond-SunRay- ... 9772wt_722
Oh and I'm the annoying new Guy ;)
Eric
Serenity is offline   Reply With Quote
Old 06-12-2012, 10:19 PM   #15
Diesel Dan's Avatar
Engine: DT466/AT545
Yeah the chest freezer hack is a great idea if your space allows and you don't need a freezer. I definitely need a freezer (I use ice packs for my sore old back!), and I need the door to open in the front since it will be under a cabinet.
Gallery:
Conversion Thread:
Old 06-12-2012, 11:53 PM   #16
syke's Avatar
Chassis: All American RE
I've read in a few places that the motor will run a bit hotter with a MSW inverter. Therefore I'm planning to run a PSW with our chest fridge and freezer. Heat and motor longevity along with a small living space and I'll be needing all the coolness I can get.
We're running a similar setup to what you pictured Bansil. Been living with it in the sticks and bricks for about 8 months now. They are going with us into the bus.
Fridge runs 202 watts per 24 hours. 34 to 37 degrees F
Freezer runs 546 watts per 24 hours. Minus 1 to 4 degrees F
Running wattage starts around 140 and slowly drops to about 100 before the fridge or freezer shut off again.
Start up is hard to measure with my Kill-A-Watt as the unit shuts off during start up. I'm guessing over 2000 watts.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
help with fridge vent lornaschinske Heating, Cooling and Appliances 5 06-11-2017 10:56 PM
Pure Sine VS Modified Wave Inverters TygerCub Conversion General Discussions 8 08-05-2012 09:06 PM
Smoothing out a modified sine wave AC signal icnivad Conversion General Discussions 2 02-06-2012 06:37 PM
Sine wave inverter alert Ob1 Conversion General Discussions 6 09-22-2010 08:15 PM
Propane Fridge ezbme Everything Else | General Skoolie Discussions 5 05-08-2009 09:17 AM
