Old 05-02-2019, 12:21 AM   #21
tugboater's Avatar
Chassis: Saf T Liner MVP 11 window 32’
Engine: CAT 3126E
Originally Posted by Compass View Post
Will you still have many of the original bus windows exposed? Single pane bus windows are leaky and non insulators. You can put hundreds into insulation, but if you're keeping the windows, it'll diminish the efficacy of any insulation project.
I put 1/4" pink foam board on the floor under my subfloor j6st as a thermal break, it's only 1.0 r rated...
ID:	32670No windows right now, We’ll be placing RV windows at some point. I decided to go with 1.5” XPS & 3/4” ply for the floor.
One...slow...step...at a time.
tugboater is offline   Reply With Quote
Old 05-02-2019, 08:47 AM   #22
Compass's Avatar
Engine: DT 466 Int.
Rated Cap: Depends on gender
Insulate away! ��
Compass is offline   Reply With Quote
