Old 06-14-2017, 10:06 AM   #21
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
its unusual for someone to throw away a reefer that works .. the fact its comoressor was gone makes me wonder if the engine is popped..
Yeah, could be. I dunno what the components cost. If the compressor was fried would it still have windings like a regular compressor? Being that the entire trailer was there, I'm hoping the evap, trailer itself, compressor, etc is what died.
The slow documentation of the build...
https://www.skoolie.net/forums/f11/9...ome-17761.html
Old 06-14-2017, 10:09 AM   #22
Chassis: International S3800
depends on the reefer.. most used a direct driven-by-engine compressor and then electric fan motors for evaporator and condensor fans,, the compressor was bolted to the output shaft of the engine directly.. not belt driven.
Old 06-14-2017, 11:30 AM   #23
Brewerbob's Avatar
That part I believe is the case. The big empty spot directly behind the motor had to be the compressor. Coils were up top. Seemed to be a shelf unit kinda thing. Engine and compressor down low. Radiator and condenser up high near the roof of the trailer. There was a fairly large tank that looked too big to be just a reservoir/radiator.
Old 06-14-2017, 11:35 AM   #24
some of them were vertical where they mounted on the front side of a trailer and stood up vertically... others horizontal units that mounted on the top front corner of usually a box truck.. the reefer would overhang the cab.. that type would look like it is meant to sit on a shelf..
Old 06-14-2017, 01:19 PM   #25
Brewerbob's Avatar
This was mounted to the trailer and was almost as tall as the trailer itself. Very thin profile as these things go.
Old 06-14-2017, 01:39 PM   #26
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Depending on how old it is Carrier uses Kubota and Thermo King uses Isuzu engines
somewhereinusa is online now   Reply With Quote
Old 06-14-2017, 02:58 PM   #27
Brewerbob's Avatar
Don't know if it was a Carrier even. There was a bus with a ceiling (not roof) Carrier. I didn't see any vents going outside on it. Was above the rear e-door and fit completely within the curve of the ceiling. Need to go back and check it out too.
