12-26-2019, 08:56 AM
Off brand diesel coolant heaters
Does anyone know ANYTHING about these guys (retailer or manufacturer)? This is a 12K (41k BTU) diesel coolant heater. for $550. Name brands are double that. Kinda nervous about buying from something that looks so shady. Would rather order from something that looks more like a store front but was told Alibada is legit at least.
https://www.alibaba.com/product-deta...4b9e5a8c4zWiYB
12-26-2019, 09:03 AM
For sure there is a lot less info out there about the off brand coolant heaters vs the air heaters... People are installing the air heaters in everything from skoolies and boats to pickups and vans to garages and cottages. I saw an initial review video of a combo air+water heater the other day but you can't really compare a 5KW air+water unit to a 12KW water one.
Alibaba is a legit marketplace just like Amazon is a legit marketplace... but that doesn't imply anything about the quality of the product you're buying. I'm not aware of anyone with a coolant heater that isn't a name brand unit.
12-26-2019, 09:14 AM
Chassis: International 1753
Engine: 6.9 International
Looks similar to a webasto unit I just fixed for a guy. I'm sure it's just a stolen design that some place in china is mass producing, screwing over a legitimate company.
The one I fixed had a control unit in the cab that operates the heater, so make sure it has that or it's no more then a paper weight.
12-26-2019, 10:54 AM
Chassis: TC2000-8 Window
Engine: Cumm ISB/Allison 2000
I've been using a 5kw unit for about two months and it has worked like a champ! I think that I paid around $130 for mine.
Mine is not being used for living space heating, but is being used to warm my FLA house battery. I had been having problems with capacity due to the cold weather. Problem solved!
Also, it is very efficient on fuel usage.
12-26-2019, 11:08 AM
$130 is either one hell of a used deal or air.
12-26-2019, 11:36 AM
I recently picked up an air heater for $110 with all the accessories.. but it's an air heater, not a coolant heater. They're a dime a dozen.
12-26-2019, 11:55 AM
Yeah, before I went this route I figured the coolant would be 2x the air. So much for that idea.
12-26-2019, 12:01 PM
Sounds like what you describe is a diesel AIR heater. This thread is about diesel COOLANT heater. Huge price difference between the 2.
12-26-2019, 01:12 PM
Yep, I've had a problem with being full of hot air before...
12-26-2019, 02:06 PM
Chassis: GA39530
Engine: DT466E 215hp 620tq
Rated Cap: 40
Water Heater
Ive been looking at one of these also but I was planning on using it in conjunction with a marine style water heater. Use the diesel heater to heat up the water heater tank. Eliminate the on demand unit i have installed. The goal would be to try to only need one fuel.
Next would be a Wallas or Wabesto diesel cook top.
12-26-2019, 02:12 PM
There are dozens of forums hundreds of threads, facebook support groups etc on these, GIYF
12-26-2019, 02:17 PM
That's the plan.
12-26-2019, 02:18 PM
For the air heaters, yes. For the name brand coolant heater, yes. For the knock off coolant heaters, NO.
12-26-2019, 02:39 PM
12-26-2019, 02:43 PM
Thx, checking now. I'm not sure 5k will do tho I could add a diesel air to the line up.
12-26-2019, 02:49 PM
And hard to make suitable for HWS-only in summer.
But redundancy is good, all the diesel ones really like running flat out not throttled down.
My desire to fuel with gasoline is an even bigger challenge
12-26-2019, 03:09 PM
Yeah, I'll probably do a smaller loop for that.
I've read that too.
Pretty sure I saw a gasoline one on this same site.
12-26-2019, 03:16 PM
01-01-2020, 08:38 PM
I've read that too.
My Corvair had a gasoline heater.
The gas heater on Ricky Nelsons C-47 airplane killed him.
01-02-2020, 05:53 AM
Chassis: AARE
Engine: 3116 Cat 250hp
I don't know about the knock offs. My genuine Espar has four heat levels. The knock off looks exactly like it.
