Old 06-01-2010, 01:06 PM   #21
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: Oh no. Dometic RM-2410 fridge flatlines...
Originally Posted by DarrenDriven
...I ran out of propane...
It happens...
Old 06-01-2010, 02:49 PM   #22
crazycal's Avatar
My first good laugh of the day. Sorry, I'm not being mean, but it was funny. I do stuff like that all the time. You're man enough to admit it. That speaks volumes. I know plenty of people that wouldn't fess up.
I'm hungry!
You Gotta Let Me Fly
Old 06-08-2010, 01:47 PM   #23
crazycal's Avatar
Someone correct me, but doesn't the cold air flow from the freezer flow to the fridge? Maybe there is an obstruction.
I'm hungry!
Old 06-08-2010, 11:13 PM   #24
sportyrick's Avatar
Chassis: F33695
Engine: 427 chevy
the facts and only the facts: the fridge worked when it was bought; it worked in your garage; yet it won't work in your bus,what could the problem be? Your install. I HAD the same problem you now have and it was my vents. If you look at most trailers and RV's they have a lower vent and a vent in roof, VERY POSITIVE CONVECTION. I looked at your pics and you don't have near enough upper vent, mine is 16x16 and I bent the lovers a little more like level to get more convection and air movement. You can't turn a corner with the air and get it to move correctly like you have, it's got to be changed and the vent enlarged greatly. Also the vent needs to be raised for better performance, out the roof for best performance. 2) the propane heat is way more BTU'S over what is needed to get it to cool properly and the extra heat is getting trapped in the rear area and killing the cooling. It gets worse when the sun is heating the side of the bus. I actually installed an exhaust pipe to exhaust the propane heat and fumes to get them outside the fridge area and get rid of that heat and that helped a lot. In my ancient 3 way Dometic I run gas to get it going or during the night and electric during the day or when ever I can to make sure my stuff stays cold, especially in hot weather. The pipes don't corrode on the inside or these things wouldn't work for decades. Try running yours without the grill and I bet it works better. Sorry but you are going to have to completely redesign your fridge install but in the long run you will be very glad you did, they kick ass. Also it takes mine 24 hours to get to optimum temperatures. sportyrick
Old 06-09-2010, 12:40 PM   #25
Send a message via AIM to baadpuppy Send a message via MSN to baadpuppy Send a message via Yahoo to baadpuppy
I don't know if you've seen the manual yet. It has troubleshooting steps as well as the all important installation criteria.
http://gasrefrigeration.net/dom_techdata/2552.pdf
I hope this helps,
jim
baadpuppy is offline   Reply With Quote
Old 06-09-2010, 07:25 PM   #26
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Pup;
Thanks for the information! I'm filing it for reference.
M1031 is offline   Reply With Quote
Old 02-02-2016, 11:36 AM   #27
thecrabshomestead's Avatar
Coachwork: Genesis International
Hey all, great thread! I am about to build the box and install my propane norcold. The directions are a tad overwhelming..but it seems easy enough. I just want to make sure on a few things. I have figure out what the hell a baffle looks like lol. And did anyone need to install insulation on either side of theiR fridge? Noticed some rv folks had them on some youtube vids but i dont think that it is totally needed...
Mocrab
https://thecrabshomestead.wordpress.com/category/tiny-house-skoolie/
thecrabshomestead is offline   Reply With Quote
Old 02-02-2016, 01:31 PM   #28
Any added insulation will just make the compressors work that much easier. But only if properly vented. Those puppies generate quite a bit of heat making cold.
Old 02-02-2016, 02:00 PM   #29
Thanks! Good to know. I do plan on taking the manual and other advice on venting on the bottom wall and through the roof. My fridge came with neither vents...i think its just covers tho so shouldnt be too hard to find. I was just getting lost with the baffles, insualtaion, and the whole bottom vent needing to be level with the floor of the fridge..i overcomplicate things loo
help with fridge vent lornaschinske Heating, Cooling and Appliances 5 06-11-2017 11:56 PM
Dometic Propane Refrigerator Kelecri Heating, Cooling and Appliances 11 01-09-2017 07:04 PM
Propane Fridge ezbme Everything Else | General Skoolie Discussions 5 05-08-2009 10:17 AM
Tips for installing Dometic 510 PeterBird Plumbing, Water and Waste 3 02-28-2008 11:34 PM
Dometic refrigerator info needed...... eggman Everything Else | General Skoolie Discussions 5 10-27-2006 11:17 AM
