11-17-2019, 08:55 AM
Year: 2008
Chassis: Saf-T-Liner HDX
Engine: CAT C7 300hp w/retarder
Rated Cap: 46 + 1 36,200 lbs
Questions About Plumbing for Propane
I am looking at a used cooktop that I would have to convert for propane use. It has a regulator at the appliance. If I regulate the propane at the tank, do I need a regulator at the cooktop? I would also like to operate a tankless water heater. At this moment I am not sure whether it will have its own regulator. So, how best to plumb for propane in such a situation?
11-17-2019, 09:12 AM
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Regulators on both. Only 1 regulator/appliance. Is the cooktop setup for propane or natural gas? You'll need to know, as regulator and nozzle sizes are different.
Some ideas on plumbing propane appliances without needing hard piping installed:
https://www.amazon.com/gp/product/B0...ZVSLD8MY&psc=1
You'll need to know the inlet fitting sizes of each appliance to ensure proper fitment.
As you are likely aware, propane can be extremely dangerous if not installed properly. Take your time, ensure fittings are tight, then using dish soap and water sprayed on all mechanical connections to check for leaks after pressurizing these appliances with propane.
If unsure of anything, seek out a qualified plumber to ensure your safety.
Good luck...
11-17-2019, 09:33 AM
Year: 2008
Good luck...
The cooktop is a nice two burner KitchenAid unit set up for natural gas. It is old enough that KitchenAid does not support it with parts for propane conversion. I think that I can still manage to get it to work with propane by changing the orifices and using a regulator sourced elsewhere. Pipe dope and bubble soap will be my close companions for the project
11-17-2019, 09:44 AM
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
Make sure you don’t use the dope with flare fittings.
11-17-2019, 09:47 AM
I like continuous piping in closed areas.. ie continuous copper tube through the walls. and the joints are located somewhere that is not completely sealed.. meaning where air can get to it.. that way a small leak either produces an odor or dissipates .. joints are easily tested for leaks since they are accessible..
definitely a regulator at the tank so you run already lowered pressure gas through your piping asnd then a regulator at each appliance.. not sure i'd hack together a gas cooking appliance, but thats just me when it comes to fire...
also remember if you are using copper piping dont us compression... either braze the lines or flare fittings...
11-17-2019, 10:12 AM
Year: 2008
Never have brazed copper only soldered. Flaring it’s not too hard though, and there’s always that corrugated steel flex tubing.
11-17-2019, 11:15 AM
Good luck...
Don’t use those hoses.
Read NFPA 1192.
11-17-2019, 11:45 AM
Flaring copper coil is easy, copper pipe, not so much.
11-17-2019, 04:09 PM
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Rated Cap: 87, says Gillig...
Originally Posted by Danjo
Read NFPA 1192.
Funny guy...
11-17-2019, 04:17 PM
It would be a good idea to bench test the stove with propane before you install it.
11-17-2019, 04:37 PM
Year: 2008
11-17-2019, 04:38 PM
Year: 2008
Absolutely!
11-17-2019, 08:07 PM
The flare on copper tubing used to carry propane MUST be perfect. Flaring isn't rocket science but a bad flare like this "factory original" I discovered in my new to me stove and heater propane set up could turn your bus into a rocket. Note the small crack in the bell of the flare. That tiny crack leaked enough propane to add a peculiar aroma to my bus from time to tine but never enough of a leak to set off the propane sniffer. Soap suds didn't show a leak--until I pressurized the complete system with 10 psi air and that did it. Jack
11-17-2019, 08:23 PM
Personally I would use a NiCop (nickle-copper alloy) line and double flare the ends like a brake line. The NiCop is much stronger but still easy to bend and flare, the double flare is much stronger than a single, way less likely to crack from the vibration.
11-17-2019, 09:14 PM
Read NFPA 1192.
So, what's wrong with using hoses specifically made for propane appliances?
Also, how about posting a link to what you think applies in NFPA 1192 for RV's, without having to purchase an $80. manual. Thanks, in advance...
11-17-2019, 09:20 PM
Outdoor use only.
11-17-2019, 09:31 PM
Outdoor use only.
I'm not seeing the notation "Outdoor use only" on those hoses. They're made for Mr.Buddy, and other propane heaters and cookers that can be used inside a bus.
I have seen a Coleman single burner propane cooker that is labeled for outdoor use only, but what's the difference between that and the propane stove tops found in commercially made RV's that are perfectly safe to use inside?
Seems safe enough to me, and I'd certainly take my chances with those S/S braided/covered propane appliance hoses over a "bare" rubber hose...
11-17-2019, 09:54 PM
Except for abrasion there isn’t any difference between that and a bare hose, except that you wouldn’t be able to see the a potential problem under it. I would consider any “rubber” hose, armored or not, to be an outdoor-only gas line. Maybe you never have a problem. Doesn’t seem worth the chance of a fitting blowing off while you’re cooking.
11-17-2019, 11:02 PM
Year: 2008
I have made my own brake lines out of that stuff. My only question is, will it work with the fittings that are available to connect to appliances and pipe.
11-18-2019, 01:31 PM
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Not speaking specifically to the issue of propane, but the reason I try to learn and comply with even remotely applicable building codes, where they don't conflict with other more applicable codes or obvious common-sense for a particular situation, is because of what I don't know, rather than what I do. I view building codes as, at least in part, the collective trial & error knowledge of countless builders, over a great expanse of time. It's the answer to all those "why can't I use x here" questions without having burn down something to realize what didn't appear obvious at first glance. Not saying code adherence is the only answer, or even the best. But IMO, if you're going to conflict with code, it should be based on a thorough understanding of the situations such code was meant to prevent, as well as how your solution will better address such issues.
Also - NFPA 1192 is specifically for RVs. So everything in it applies to RVs
Finally, you can create a free account & view any of those documents online, Pete. Just click on the 'free access' button, and it will prompt you to create a free login account if you don't have one already:
https://www.nfpa.org/codes-and-stand...tail?code=1192
Go away. 'Baitin.
Our Build: Mr. Beefy
