Old 09-01-2016, 12:05 PM   #1
karrlot's Avatar
Coachwork: Ward
Rated Cap: 65 passenger
Removing the rear heater
When I remove (or temporarily disable) the rear heater, can I just cap the coolant lines so no coolant is flowing to the back of the bus?
Or do I need to hook them back together so the coolant can flow from the engine out one pipe and back into the engine through the other pipe?
Please check out my blog-
Follow the (lack of) progress on the Karr Family Kamping Bus Blog
Here is my woefully inadequate build thread:
https://www.skoolie.net/forums/f11/i-...bus-12296.html
karrlot is offline   Reply With Quote
Old 09-01-2016, 12:46 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
If you are removing all of the heaters you can block them off, if keeping front heat/defrost you need a loop.
Old 09-01-2016, 08:18 PM   #3
New2Skool's Avatar
Coachwork: Carpenter Body
Rated Cap: 65 to Zero. Folding Chair
The heaters run on a loop.
If you remove the rear heater, just bypass it at the mid heater and close the loop.
As far as avoiding a mess, I parked at an angle and cut the lines preventing leakages or spills.
I helped a friend remove the rear heater and he just temp clamped the hoses and reattached to complete the loop at the mid ship heater.
D.L. Jones III
"The Independence"
98 International
New2Skool is offline   Reply With Quote
