Old 11-27-2012, 09:51 AM   #1
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
rooftop vent
Hi guys,
what is the purpose of the rooftop vent, is it needed more in the summer or winter? also i see no way to close it, and i know heat escapes from there. for the summer i was thinking of installing a computer fan in there. does anyone remove their vent? here are a couple of old photos that show it:
http://i1063.photobucket.com/albums/t50 ... NY3493.jpg
http://i1063.photobucket.com/albums/t50 ... NY3792.jpg
proconsul100 is offline   Reply With Quote
Old 11-27-2012, 12:27 PM   #2
GreyEagle's Avatar
Re: rooftop vent
I figure, (really don't know) but I'd guess it to be a fresh air vent for the summer.....
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 11-28-2012, 09:47 AM   #3
Year: 87
Re: rooftop vent
i agree, but there really is no way to close it.i see them on a lot of school busses. I might try to rig up a way to close it that would be recessed so i wont bump my head on it
Old 11-28-2012, 10:22 AM   #4
Diesel Dan's Avatar
Engine: DT466/AT545
Re: rooftop vent
You're lucky, I can't even see or access my vent from the inside. I have an acoustic ceiling in front so the vent must just open up between the inner and outer layers of the ceiling/roof. I have wondered about the disadvantage of having a portal for air to escape that cannot be shut down - especially in the winter when you are trying to heat your bus. If I had easy access to mine I would definitely want to create a way that I could shut it down as needed - even if it was just a "plug" of some sort that I could shove in there and then remove when not needed. My first thought would be a piece of wood with insulation on top and a rubber gasket around the edge to seal it and help to hold it in place. Perhaps there would be magnets involved to hold it up? Or perhaps there would be a lip on the bottom of the ceiling and you would angle the plug in and then let it settle down flat on the ridge. Just brainstorming easy fixes here... Without seeing a closeup pic it's hard to know what options you have to work with. Hmmmm... now I'm tempted to cut a hole in my ceiling and do something with my vent as well...
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 11-28-2012, 11:02 AM   #5
Re: rooftop vent
That roof vent must have been required by the original bus gods because even my 1935 has one--it can't be shut off and has a drain trough for water. I'll be welding it shut as there are PLENTY of other places for air to get in Jack
Old 11-28-2012, 11:30 AM   #6
crazycal's Avatar
Re: rooftop vent
If you go to Home Depot or Lowes, you can probably find a magnetic cover that fits over your vents at home. They would work.
I'm hungry!
You Gotta Let Me Fly
Old 11-28-2012, 11:39 AM   #7
crazycal's Avatar
Re: rooftop vent
http://www.homedepot.com/buy/frost-king ... 815/3.html
I'm hungry!
Old 11-28-2012, 12:58 PM   #8
Re: rooftop vent
that would be $$$ he'd need probably about 40 of them...might look cool if you painted a design on them...you could change it every week
Old 11-28-2012, 02:03 PM   #9
crazycal's Avatar
Re: rooftop vent
Why would he need 40? This is for the roof vent up front, right. This is a 3 pack of 8x15". That won't cover it?
I'm hungry!
Old 11-28-2012, 03:33 PM   #10
Re: rooftop vent
His vents into the perforated ceiling, on my bus the perforated area is width of bus and maybe 8 feet long, on mine they sawed or chewed a hole in the perforated panel and had a drier ducting taped to the top vent and a screen on the perforated place...so they could close it off, during the summer I had a 4 computer fan powered by a solar panel to keep air pulling out, it helped a lot
rooftop wind deflector fishphart Classifieds | Buy, Sell, Swap 0 09-15-2011 04:29 PM
luggage rack / rooftop storage Atridox Conversion General Discussions 1 04-02-2010 09:48 AM
Rooftop Decks arfisher83 Conversion General Discussions 9 08-13-2009 03:05 PM
Running Rooftop AC down the road... NewSkewlHauler Conversion General Discussions 2 06-16-2009 09:40 PM
