Old 05-30-2010, 09:21 PM   #1
running a chest freezer on it's side.
Hey, I have a pretty new 7.0 Holiday chest freezer, and it' not the optimum shape/size for the space available in my bus(about 3.7" high by 4' wide by 3' deep). Does anyone know if I can turn this thing on it's end and have it run ok? If not as is, would it be simple to modify it so it can be run this way? I've heard that they can't be transported on their side, but I wasn't sure it this still applies to new freezers or if it would be easy to flip the compressor(or whatever has problems being on it's side).
If so, I'd like to get a second one of these and have one set to freeze, and one set to cool. Combined they would take up about the same amount of space as my current single. I've looked into getting something that's designed a little better for my space, but I can't find anything that will fit without getting into the quadruple digit range, which is a bit more than I want to spend for a fridge in the bus.
Thanks
icnivad is offline   Reply With Quote
Old 05-30-2010, 10:44 PM   #2
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: running a chest freezer on it's side.
I think there is a problem with the oil in the compressor. Thats what I have been told all my life.
The brains on the site will surely know the answer. This is a great site.
see my conversion at http://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 05-31-2010, 12:19 PM   #3
Is it just the compressor that needs to be upright? Any chance I could bend some pipes and get it remounted? Or does the whole thing need have the proper feng shui to work?
Old 06-01-2010, 06:47 PM   #4
the_experience03's Avatar
Running them at enough of an angle (on on its side is enough of an angle ) you run into problems with hydrolocking the compressor meaning you are trying to compress a liquid. Oil runs where it is not supposed to and the orifice tube or TXV is unable to properly assure that the compressor is only getting gaseous refrigerant and not liquid refrigerant.
Why I like lots of Freezer Space... lornaschinske Skoolie Life 11 06-25-2017 01:33 AM
Chest Freezer as 'Fridge in Bus swinada Heating, Cooling and Appliances 53 06-14-2012 11:00 PM
The Fun Side Tango Skoolie Conversion Projects 33 11-18-2011 11:59 AM
Chest Fridge Conversion Seeria Heating, Cooling and Appliances 3 06-07-2011 07:52 PM
running a freezer on a power inverter? dreadballa Electrical, Charging and Solar 2 10-26-2009 06:57 PM
