Old 05-02-2019, 06:58 PM   #1
Sleddgracer's Avatar
Chassis: still looking for my bus
squeaky styrofoam
has any one that has rigid foam insulation noticed it squeaking as the bus moves and flexes?
Old 05-02-2019, 07:12 PM   #2
Chassis: B3800 Short bus
I used XPS sheets on the floor with spray foam in the walls and ceiling. Not a single squeak, I'm happy to report.
Styrofoam against Styrofoam is such an awful noise. It's up there with fingernails on the chalk board
Old 05-02-2019, 07:32 PM   #3
I was warned about the squeaking from a guy at the building supply, so it concerned me a bit - and my girlfriend said the bus she once had, the squeaking from the styrofoam drove her nuts - that's the only thing I've heard her say bad about the bus she once lived in
Old 05-02-2019, 07:49 PM   #4
I hate squeaks but I knew I couldn't afford spray foam so I settled for layers of 1" R-Tech foam board. I sprayed a film of 3M 77 contact cement on each surface and slapped them in. I got lucky, I've never heard a single plastic squeak--a lot of other racket but no squeaks.
Old 05-02-2019, 08:15 PM   #5
plfking's Avatar
Rated Cap: 34
None so far. I've driven about 100 miles total since insulating.
Don
The Busted Flush
Old 05-04-2019, 02:46 AM   #6
No squeaks. However, we have only used it in the floor at present so there is not much chance of movement. We have Reflectix, then XPS, then Reflectix, then plywood, then vinyl flooring.
Old 05-04-2019, 04:43 AM   #7
The "flexing" is way overemphasized on this forum.
Roll Your Own Build Thread
Old 05-04-2019, 11:22 AM   #8
You say that now but you have never seen me flex
Old 05-04-2019, 11:46 AM   #9
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I have the occasional squeak in the floor when walking. Floating floor on styrofoam. I have no squeaks when driving.
