Old 10-12-2019, 05:40 PM   #1
Year: 2008
Chassis: Saf-T-Liner HDX
Engine: CAT C7 300hp w/retarder
Rated Cap: 46 + 1 36,200 lbs
What are these switches for?
The switches are found on the panel just at the drivers left elbow.
I suspect that the switch labeled “pump“ is for a pump to circulate heated engine coolant to the various heater cores around as the bus.
And here is one that has me even more puzzled. “comp”? And the symbology used does nothing for me.
wrenchtech is offline   Reply With Quote
Old 10-12-2019, 05:44 PM   #2
Luggage compartment lighting, heated mirror
Old 10-12-2019, 06:01 PM   #3
I have one switch labelled "NOISE KILL" which appears to have no effect other than it has to be switched to ON in order for the driver's fan (the little fan in a cage next to my head) to work. Is my wiring messed up or is that supposed to be how it works?
Old 10-12-2019, 08:56 PM   #4
plfking's Avatar
Rated Cap: 34
Is the fan loud enough to drown out......say......the sound of 30-40 kids screaming behind you?
Don
The Busted Flush
Old 10-12-2019, 09:23 PM   #5
Haha, that's the only explanation that's made any sense so far.
Old 10-12-2019, 11:10 PM   #6
Year: 2008
My bus has that “Noise Kill” switch too. At first I thought all my fans were broken and I spent a couple hours trying to trace down the cause. Eventually I figured out that they don’t work with that switch is on.
Old 10-12-2019, 11:14 PM   #7
Well that makes sense, but I wonder why mine is wired up backwards.
Old 10-12-2019, 11:58 PM   #8
The "pump" switch is indeed for the water circulation pump for the heaters in the cab. I had the same question as you did and it took me a VERY long time to find out what it controlled.
