Window A/C Power
I’m considering removing the factory split system that came on my 2003 Ford 7.3 World Trans 6 window and replacing with a window unit above the back door.
I would like to be able to power this unit when on the road and when parked. I understand I could use shore power when parked, but what’s the best way to power this unit when on the road? Is it a battery bank that’s being fed by the alternator with an isolator in-line and an inverter attached the the battery bank?
Thoughts or directions to any other post discussing the same thing?
Thank you!
