Old 01-07-2018, 12:57 PM   #1
3000 rpm
Hello all.
I recently acquired a 1967 dodge school bus that I am renovating into an rv.
My question is when driving on the highway at 60 mph it is running at 3000 rpm. Is there any way to drop the rpmís and be easier on the engine.
Iím thinking changing the rear end gear ratio but no idea where to start.
Any info and help is appreciated
Thanks in advance
File Type: jpg AC7A9A01-B9B9-476C-A941-45E62C6458DE.jpg (283.4 KB, 11 views)
Nivek1972 is offline   Reply With Quote
Old 01-07-2018, 01:16 PM   #2
Jdawgsfanasty's Avatar
Originally Posted by Nivek1972 View Post
Hello all.
Thanks in advance
Cool bus...idk about rearends...at least in this case...but, yeah, it's the easiest part to mod...
Jdawgsfanasty is offline   Reply With Quote
Old 01-07-2018, 01:26 PM   #3
Robin97396's Avatar
If you've got enough space in your wheel wells, taller tires can make a difference
Robin
Nobody's Business
Old 01-07-2018, 01:35 PM   #4
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Check the data plate on the rear axle. There should be either a plate, or a number in the actual casting that will give you the gear ratio. Call truck shops to find out if those gears can be changed to a lower ratio.
Example: my bus had a 5.29 ratio. Eaton made a now-obsolete 33233 rear axle. Chalk's Bus Parts in Houston did some digging and found they could change that ratio to a 4.11. End result was I went from a top end of 55 mph @ 2450 rpm to 72 mph @ 2400 rpm. BIG jump!
Don't take a "No" just from one shop and think they all will say that. I took over a year to find what I needed to do that change. I always asked if the person I was talking to knew if there was someone else who might have some experience with my rear axle. I never accepted a "No" answer. It may have slowed me down, but never stopped me.
Best of luck!
M
Firearms stand next in importance to the Constitution itself. They are the American peopleís liberty teeth and keystone under independence. ó George Washington
M1031A1 is offline   Reply With Quote
Old 01-07-2018, 01:43 PM   #5
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Very cool bus ! More pictures when you get a chance.
Tires and inside the pumpkin, like they said.
Welcome ! What are your plans once you get her to spin-down a bit?
Old 01-07-2018, 02:02 PM   #6
Gotta ask...what engine? That many revs in some engines is a death wish...on others...OK.
If we can determine the "sweet spot" for it, that will tell the tale on where the gears and tires should be for highway speeds.
Old 01-07-2018, 03:59 PM   #7
Hey there. Itís a 361 b series. Getting approx 10 mpg now the way it is
Old 01-07-2018, 04:01 PM   #8
More pics
Here you go
Old 01-07-2018, 04:40 PM   #9
Here you go
How much of the exterior you keeping? I saw a really cool '58 but when it was "restored"...it was a hot rod and "lowered"...stupid...anyway, I know you gonna do a awesome job...I'm just weird...lol
Old 01-07-2018, 04:45 PM   #10
great bus!!!
being a Hot-rodder myself I think slammed and unusual busses are kickass..
