Old 11-06-2015, 07:46 PM   #1
Chassis: CSFE
Engine: 5.9 Cummins ISB
Rated Cap: 25
5.9 cummins isb
I am having trouble starting my 2002 Bluebird CS bus. When I turn the key on, all the lights and buzzers come on. The grid heater works. When the light goes out and I try to start it, it does nothing. The starter does not even try to work. I can hear at least two solenoids working when I do this. I cleaned all the battery and major connections under the bus. The fuel pump sounds like it is working. Searches suggest maybe fuses or a broken wire. Can anyone tell me what maybe wrong.
Eric A. Hinkley
railbus5 is offline   Reply With Quote
Old 11-06-2015, 08:29 PM   #2
2kool4skool's Avatar
In "N" ? Had to ask....
Don, Mary and Spooky the cat.
Old 11-06-2015, 08:35 PM   #3
OMGIBoughtABus's Avatar
Chassis: Saf-T-Liner
Engine: Cat 3208
Rated Cap: 84 px
yup,I've had a brain fart and did that... called a tow truck for a jump, the driver is like uhhh... did you know your backup lights are on? At least he didn't charge me...
OMGIBoughtABus is offline   Reply With Quote
Old 11-07-2015, 05:42 PM   #4
Chassis: CSFE
Rated Cap: 25
i was sure it was. I checked anyway. The shifter has a lock for each position. I wiggled it and moved it thru the gears. No dice. It still will not start.
Eric A. Hinkley
Old 11-07-2015, 05:57 PM   #5
Engine: Cat 3208
Rated Cap: 84 px
Well, one more thing you can try maybe...
My bus won't start at the ignition. Won't even turn over. I have to turn the key on and go in the back and start it with the button in the engine compartment (while holding in the engine door safety switch).
Don't know if a Bluebird has a similar setup to a Thomas though.
Old 11-08-2015, 09:19 AM   #6
Chassis: CSFE
Rated Cap: 25
Mine is a front engine. Bluebird rear engines do that.
Eric A. Hinkley
Old 11-08-2015, 12:15 PM   #7
crazycal's Avatar
Did you try to jump the starter directly? Also, time to get the test light out.
I'm hungry!
You Gotta Let Me Fly
Old 11-08-2015, 06:10 PM   #8
Chassis: CSFE
Rated Cap: 25
No. Because it does not look like most starters I have dealt with before. It has two large cable clusters. 1 is positive and 1 is negative. I can't locate anything else because of large wire groups in the same area.
I have been checking circuits with my tester. So far everything has the same voltage as the battery. I also pulled all the dash fuses and check for resistance. All were good. I did find the high idle switch on and turned it off. Still nothing. I listened under the hood and heard a click and short buzz when I turned the key on. I am assuming that means the shutdown switch has turned on and the grid heater is coming on.
Thanks everyone for your help so far.
Eric A. Hinkley
Old 11-14-2015, 09:49 AM   #9
crazycal's Avatar
Did you check you emergency exit interlocks? On some buses, if you have the door locked, you can't start the bus. Door must be unlocked.
I'm hungry!
Old 11-14-2015, 08:32 PM   #10
Chassis: CSFE
Rated Cap: 25
This particular model has no true emergency doors. It has large windows that have bottom releases so you can swing out the whole window an escape. It does have a back door for a wheelchair lift. A buzzer sounds and some lights come on when it is opened. I removed the lift but, I have started it since then.It was sold as a passenger bus for city use or more commonly site seeing tours. Mine in particular was a ski bus for most of it's life. It transported skiers from parking lots to the base lodge.
I have made some contacts and it was suggested that the batteries were on the weak side. I have replaced them. Still no. I have been told by a former bus driver/mechanic that if I had corrosion everywhere than the starter is probably full of it. I am removing it now to test it and see. I need special torx wrenches to remove it. I've had to order them. Now I wait.
Thank you for your suggestion. It was much appreciated.
Eric A. Hinkley
