Old 12-28-2017, 07:58 PM   #1
JesuitJohn's Avatar
Chassis: Saf-T-Liner
94 Thomas Safety Liner - JesuitJohn retreat
I just got hold of a 1994 Thomas Saf-T-Liner HDX and plan to convert it to a retreat spot in South Louisiana. As a retreat spot, it won't need to remain mobile and can get by with a single twin bed. I will need to cook in it and wash up, but I won't be desperate for storage space. It gets hot here, so I'm planning to go solar and run a small window AC unit.
I've used most power tools at some point in my life, and I've done some modest home renovation work like demo, putting in flooring, painting etc... But I'm no expert at anything like this, so advice is appreciated!
JesuitJohn is offline   Reply With Quote
Old 12-28-2017, 08:06 PM   #2
Robin97396's Avatar
Welcome John
What engine and trans do you have in that bus? You might be able to recoup your purchase price.
Robin
Nobody's Business
Old 12-28-2017, 08:06 PM   #3
Chassis: Saf-T-Liner MVP ER
Welcome, and nice bus.
What you have there is a Thomas Saf-T-Liner MVP RE. It may be the more coveted "RE" or "West Coast", hard to tell from the pics.
It is not an HDX. They were not launched until 2001.
What engine and transmission does it have?
Steve Bracken
Build Thread
Old 12-28-2017, 08:12 PM   #4
JesuitJohn's Avatar
Originally Posted by Robin97396 View Post
Welcome John
Its an automatic diesel. I wasn't thinking of selling, but maybe you are right!
My current plan is to park it near a shop I can use (did that today) and work to get it partly in shape there. Then, drive it into the woods and finish up the "mud room" front room starting with ripping out the driver's seat and dash etc...
I suppose I could sell the engine, then just tow it to the woods?
So much to think about.
Old 12-28-2017, 08:16 PM   #5
JesuitJohn's Avatar
Thanks for the clarification!
How can I tell what I have? I've got more pics if that helps.
I noticed from some others on YouTube that my bus is odd. It has no roof openings.
Old 12-28-2017, 08:19 PM   #6
Robin97396's Avatar
I was thinking more like you get it where you want it first and then possibly capitalize on the engine and transmission.
If you're eventually taking out the driver's seat and dashboard it's not like you'll be moving it without a wrecker anyway.
At the same time it would be a shame to gut such a nice bus.
Any chance you could take a couple pics of the engine to post here?
Robin
Nobody's Business
Old 12-28-2017, 08:24 PM   #7
JesuitJohn's Avatar
I can, but it'll be a few days. Keep an eye out! I live a few hours away from where I will be working on the bus. Here are a few other pics.
Old 12-28-2017, 08:36 PM   #8
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
The rare-as-hen's-teeth Thomas WestCoast-ER was an uprated version of the regular Saf-T-Liner (not of the less expensive MVP), designed to compete with Crown and Gillig. It had heavier-duty specifications than a Saf-T-Liner, and some even had dual rear axles. I looked at a WestCoast-ER that Ramona SD was selling - it had a CAT 3208T, full air suspension and disk brakes! Nice buses.
Old 12-28-2017, 08:39 PM   #9
As you go in the door there are two data plates on the right of the front panel (above the windshield).
They will tell you most of what you need to know
Steve Bracken
Build Thread
Old 12-28-2017, 08:40 PM   #10
JesuitJohn's Avatar
I'll have look and see what I got! I'd hate to think I was missing an opportunity. Thanks for the info.
1994, saf-t-liner, south
