Old 05-01-2016, 02:46 PM   #1
Big red
Recently bought a 2001 IH school bus with the DT360 Engine. Took a few weeks in between work to sand the entire bus and prep for paint but in the end it looks perfect. Going to be using it for motocross.
bigred121 is offline   Reply With Quote
Old 05-01-2016, 03:24 PM   #2
Robin97396's Avatar
Yay, another bus with a garage? Sounds like you got a shorty. Don't take that the wrong way.
If my quad was 2" narrower it would fit through my wheel chair door.
Old 05-01-2016, 04:58 PM   #3
It wont let me upload a picture but it is a full size bus with the carpenter body.
Old 05-01-2016, 05:45 PM   #4
yeaay for a fellow Carpenter!
Old 05-01-2016, 05:57 PM   #5
Robin97396's Avatar
Upload your photos to photobucket then transfer to here.
Old 05-01-2016, 09:14 PM   #6
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
... Going to be using it for motocross.
Dapplecreek is offline   Reply With Quote
Old 05-01-2016, 09:27 PM   #7
Robin97396's Avatar
Yeah it's hard to resist catching air with a bus.
Old 05-02-2016, 08:43 AM   #8
Never caught air.. but my little bluebird, after I got done with the 454 in it, that bus would squeal the tires.... im sure the '545' didnt like it (I think thats what it had for a trans). but I never blew it up...
Old 05-02-2016, 09:33 AM   #9
Robin97396's Avatar
I'm pretty sure I catch air sometimes on these back roads. I'm finding that this FE drives considerably different than a conventional dog nose bus on these narrow back roads. The biggest problem is the bus seems to be the same width as half the road, which isn't a problem until you pass a logging truck that is also filling half the road. Timing is crucial so mirrors don't clank. Lost a tire and rim already by hanging over the edge of the road in a bad spot.
Old 05-02-2016, 09:44 AM   #10
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
those off-road images are hilarious!
As far as posting pics, if you have a smartphone, try tapatalk.
60% of time, works every time!
n00b build > https://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 05-03-2016, 08:52 AM   #11
Bansil edited your picture so it worked
