Originally Posted by _Bus_102_
Sad news today I tried to crank the bus for the first time and it didn't even turn over. I have two batteries. If I can get help of how they hook up right I will really appreciate it
Sent from my Alcatel_4060A using Tapatalk
I am not sure exactly what your question is.
Most full sized school buses had two 8D batteries wired together (parallel) with positive and positive wired together and negative and negative wired together.
Sometimes, in older equipment, you may find someone has wired batteries in series. In order to get 12-vdc out of 6-vdc batteries you need to wire the batteries in a series with positive on battery one connected to negative on battery two and negative on battery one connected to positive on battery two.
https://www.batterystuff.com/kb/arti...-tutorial.html
