Old 05-07-2017, 01:39 AM   #11
_Bus_102_'s Avatar
Originally Posted by 1olfart View Post
Congrats on the 101. Wishing you all the best on your build.
PigPen and Chris are correct in suggesting you follow up with ALL your future posts on this thread. Old guys like me have a hard time following more than one thought at a time
Ok. I'll try my best
Sent from my Alcatel_4060A using Tapatalk
_Bus_102_ is offline   Reply With Quote
Old 05-07-2017, 01:01 PM   #12
_Bus_102_'s Avatar
Does anyone know how to turn a bus that has no AC into one with AC
Old 05-07-2017, 01:32 PM   #13
Robin97396's Avatar
The current trend is to buy a mini-split system to air condition your bus. You will probably need to install insulation is you want to the AC to be effective.
Robin
Nobody's Business
Old 05-07-2017, 01:33 PM   #14
_Bus_102_'s Avatar
Ok
Old 05-07-2017, 03:27 PM   #15
Chassis: International S3800
how do you want to A/C? when parked and the engine off or when driving? the 2 are very distinctly different..
if you are plannin on super-insulating your bus and really working around getting rid of engine heat sources, then 2 mini splits can make you somewhat comfortable driving in hot weather in a full size bus.. thats assuming you have a way to run them when driving, ie a generator running..
being parked, 2 mini splits (24,000 BTU total) will keep you nice N cool as long as you have done some decent insulation in the walls and ceiling...
what is your plan of driving vs being parked? and how do ytou plan to power your bus when parked? generator? solar? plugged into shorepower outlet?
in my case i drive all the time so I have busses with regular road (engine driven) A/C.. basically like a car system only much larger.. and just a portable A/C that works off a large battery bank for the short times I want to run air while parked.
