Old 03-01-2016, 06:10 PM   #1
Chassis: Bluebird
Engine: Cummins
Rated Cap: 73
Converter to power skoolie lights
Hi guys I have a 91 Bird, I have ac power done but I want to use the original interior bus lights as my light source, without draining my bus battery, I have a working converter from a 78 rv, but I'm hesitant in where I should hook up the converter, any clues would be great
toasterman12 is offline   Reply With Quote
Old 03-01-2016, 06:37 PM   #2
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
You would connect your converter to the bus wiring at the switch where the lights are currently converted. However, you have to connect it on the load side of the switch to avoid energizing the rest of your buses equipment.
here is a diagram...
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
original interior lights
