Old 02-05-2019, 06:13 PM   #1
Chassis: International FE300
Engine: Dt466e
Coolant filter DT466e
Hey guys, I appreciate the knowledge and willingness to share it on this page! Been following since I started my conversion in April but just recently ran into an issue I can find the answer to. I have a 2004 Thomas FE300 flat nose bus with a DT466e in it. Since I purchased it the overheating lamp and buzzer has chirped when driving it. However the temp gauge always read around 205 so I assumed it was a bad sensor for the light. Unfortunately I recently discovered that it was actually a faulty temp gauge as it wont go above 205. Unfortunately that also means I drive my bus a few hours with it being hot and I am hoping I didnt cause damage to the sleeves. Anyway, I'm in the process of oil/tranny/fuel/coolant fluid and filter changes. Had no issues performing all with the exception of the coolant/water filter. Everything I've read points to my bus having a coolant filter but for the life of me I can not find it. It's a decent sized filter (or at least the one they sold me is!) So would think after a dozen times crawling all under the bus I'd be able to find it. Can any of you guys point me in a direction of either confirming I do not have a filter or where it might be located? I believe they may be a blockage in my system and want to eliminate all possibilities. Thanks!
Entech.medic is offline   Reply With Quote
Old 02-05-2019, 06:43 PM   #2
We've got a mechanical DT466, so it might be different....but I think I remember it being horizontally mounted, and it was definitely on the passenger side of the engine about 1/2 way up? There's a petcock you need to shut, too, that cuts off flow to the filter. Don't forget to open the petcock after you change the filter. On ours, the petcock was jut a little lever but the mechanic that walked me through it said sometimes they get stuck....so watch for that. Again, the 466E might be a different beast, I dunno.
Old 02-05-2019, 07:56 PM   #3
Engine: Dt466e
Thanks Drew. I've literally spent probably 2 very frustrated hours looking for it. Like I said it's about the size of my oil filter for my pickup so it really shouldn't be that hard to find. I'll remember to look for valves now too, thanks
Old 02-06-2019, 06:28 AM   #4
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
That is where it is on our 2003 DT466E (conventional).
Dave
Old 02-06-2019, 06:32 AM   #5
Engine: Dt466e
Thanks Dave. By "conventional" are you talking about a dog nose bus? I'm wondering if my flat nose has a different location? I'm at a loss and am starting to think I may not have one.
Old 02-06-2019, 08:38 AM   #6
ermracing's Avatar
Rated Cap: 29,000
I guess, front engine, under a hood, as God intended....
Dave
Old 02-06-2019, 03:59 PM   #7
Engine: Dt466e
I dont mean to sound like an idiot here, especially seeing as I've already posted one thing but even then I had trouble. Can someone walk me through making a new thread? I have another issue (now my dt466e wont start after a coolant swap) that I need some help with. Thanks!
Old 02-06-2019, 04:09 PM   #8
Engine: Dt466e
Never mind I found some info in the help section that pointed me in the right direction!
Old 06-28-2019, 10:05 AM   #9
_rideswell_'s Avatar
Chassis: FE 300
Entech.medic,
I have a 2005 FE 300 with a DT466 and I am having the same issue of locating my coolant filter. Do you have a minute to point me in the right direction? Were you able to locate it and if so where?
_rideswell_ is offline   Reply With Quote
Old 06-28-2019, 10:13 AM   #10
HazMatt's Avatar
Chassis: IH 3800, 8 window
I wouldn't hold my breath. OP hasn't been active since Feb...
Originally Posted by _rideswell_ View Post
Entech.medic,
