01-26-2017, 04:26 PM
Engine: 5.9l cummins
first time skoole converter
hi people new to this whole thing purchased a 1999 bluebird flatfront 38' 5.9 cummins 130k miles its a movie star was used in the remake of red dawn we gutted inside added new flooring and built walls for the bathroom and to seperate the bedroom off from the kitchen made a bed platform that hinges for storage the walls we built are being covered in a pallet like material and stained to match the floating floor were installing
01-26-2017, 04:28 PM
here are some on going pictures we plan on getting the floor finished this weekend and to paint so i can start putting the pallets up on the other walls then lay the new floating vinyl floor
01-26-2017, 04:29 PM
01-26-2017, 04:32 PM
Nice!
It looks like is coming along very Nice
01-26-2017, 04:59 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Sweet !
Looks like you move fast !
Red Dawn.... Guess you have to name it Wolverine!!
Not a fan of OSB on the floor. Marine plywood FTW.
Cool bus story.
01-26-2017, 05:07 PM
Best looking cardboard mock ups ever!
01-26-2017, 05:15 PM
Traveling
Rated Cap: '00
Sid? Vicious!
01-26-2017, 06:05 PM
not cardboard its hardboard
01-26-2017, 06:07 PM
im all for marine grade plywood but im not trying to break the bank the metal floor is completely sealed and nothing leaks so osb it is
01-26-2017, 07:20 PM
Traveling
Rated Cap: '00
So, you do know the movie your bus is from, right?
Wolverines were the resistance movement ;)
01-26-2017, 07:24 PM
yes i know the movie
01-26-2017, 07:32 PM
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
great job, wish I worked that fast!
01-26-2017, 07:34 PM
i started stripping it out 2 days after thanksgiving
01-26-2017, 07:36 PM
i plan on having everything done by end of February so all i have to do come spring is the out side metal work and paint
01-27-2017, 11:30 AM
Chassis: e450
Engine: 7.3 liter turbo
Nice work!
Impressive progress!
I just bought a bus last week, and I'm ripping up the floor now. What did you fill in the seat bolt holes with? Silicone? putty?
And what kind of sealant did you use on the metal floor?
I've read several blogs where OSB was used as subfloor . . that's my plan.
Thanks for suggestions.
01-27-2017, 11:35 AM
Traveling
Rated Cap: '00
Bluebird specified 5/8 Plywood originally on my bus build sheet.
01-27-2017, 11:57 AM
I was relieved to find only metal under the rubber on mine!
01-27-2017, 12:21 PM
Mine had plywood to but I wasn't paying that much for plywood 5/8 osb worked just fine. And after I wire wheeled the whole floor I used por15 paint then used thick roofing tar to fill in the seat bolt holes surprising for a mi bus it was in great shape
01-27-2017, 12:48 PM
Chassis: e450
Hope I don't sound ignorant, but I don't know what you mean by "por15 paint".
01-27-2017, 12:52 PM
Traveling
Rated Cap: '00
Stop Rust with POR-15 - We Know What Permanent Means!
