Old 03-12-2016, 04:22 PM   #11
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Mine's an RE, I chose it because the motor won't be running when I'm asleep in it, and I won't have to listen to it when I drive.
Plus like robin said, even if you absolutely had to work on it in the rain, mine has a built in flip up water diverter!
Welcome to the gang!
-Doc
My build thread - viewtopic.php?f=9&t=467197
Old 03-12-2016, 05:06 PM   #12
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Originally Posted by Mark_In_MA View Post
This is the size I'm thinking of.
I want the all-steel, won't pankake if it rolls over model.
Full-size truck chassis, engine/tranny.
Just missing a few feet behind that rear axle.
This looks like it has 8 windows, I'd be open to the 10-window size - its really just the full 12/13 window size I'd like to avoid, just so I don't quite have that huge overhang at the rear. I don't plan to do any real off-roading with it, but at the same time, if I go to a national park or somewhere with a dirt road, I don't want to be worrying about dragging the side skirting down the road either.
That's no fullsize. Thats medium duty.
Roll Your Own Build Thread
Old 03-12-2016, 05:20 PM   #13
Robin97396's Avatar
Egg-zacktly. That looks survivable if it goes over a cliff.
Old 03-12-2016, 06:16 PM   #14
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Ah! The Wile E. Coyote conversion!
Old 03-12-2016, 06:23 PM   #15
Robin97396's Avatar
Buses are very aerodynamic while they're going down.
In a complete vacuum a feather would fall at the same speed as a bus. Marinate on that for a while.
I weighed my bus yesterday and it clocked in at an even 19,000 lbs.
Old 03-12-2016, 06:46 PM   #16
Docsgsxr's Avatar
I think my rear axle weight is more than your whole bus! Lightweight!!
Old 03-12-2016, 09:41 PM   #17
Coachwork: IC
Chassis: CE300
Rated Cap: 32
You should actually weigh it, I weighed mine sans interior and came in at 17.9k.
Old 03-12-2016, 09:53 PM   #18
Robin97396's Avatar
If you've ever watched the bus crash tests, everything behind the drivers area looks fine. Of course they didn't have a wood stove in the back of the bus during those tests.
