Old 03-12-2019, 11:35 PM   #1
gus da bus
Hello all!
I've been lurking a short while on this site, soaking up knowledge on youtube, and other resources.
I was, at some point planning on getting a bus.. Just didn't expect it to be so soon. But as fate would have it I came across this find. I call him Gus. Gus da bus. Picture attached.. will have to figure out how to upload the image.. no doubt info on how to do that is somewhere close by.
It's a 98 bluebird with 138k miles, Cummins 5.9 24v and Allison trans. Couple unique aspects of this bus is that was built as a crew bus, and spent it's previous life ferrying fire crews, so no school bus warning lights or stop signs to live with, or remove and patch. Also it never had a yellow paint job, so what is there was there to start with and in great shape, a little TLC and it will be bright and shinny. A couple minor dings and scratches, but nothing that can't be easily fixed (or ignored). Even all the tires have full depth tread. There is even a tiny (emphasis on tiny) commode closet at the back with equally tiny fresh and black water tanks. This may help in getting the bus registered as an RV, but long term I'll yank that out and go with a composting set up. Another convenience when I start gutting the bus is that the seats are not upholstered, but are a fiberglass seating surface bolted to a steel frame. Must have been a brutal ride. It will take all of about 2 minutes per seat to separate the two, making it a breeze to recycle the frames, and junk the fiberglass. I'll be picking it up Thursday, and can post more pix then.
robertv is offline   Reply With Quote
Old 03-12-2019, 11:56 PM   #2
Wow, that looks like a nice ride ... and quite a find! Congratulations!
Old 03-25-2019, 11:32 PM   #3
Been a slight change of plans. After test driving the bus in the pic and another one... I changed my plans and went for a RE Thomas. This one has a turbo and does over 70 on the highway. The green stripe bus with the engine in the front was awfully loud at speed, and topped out at 62.
Old 03-25-2019, 11:33 PM   #4
I have all the seats out, and am working on pulling up the flooring.
p.s. thank goodness no home owners association!!
Old 03-26-2019, 12:28 AM   #5
tugboater's Avatar
Chassis: Saf T Liner MVP 11 window 32
Engine: CAT 3126E
Cool bus, gotta CAT in there?
One...slow...step...at a time.
tugboater is offline   Reply With Quote
Old 03-27-2019, 12:07 PM   #6
12V Cummins 5.9
Old 03-27-2019, 02:10 PM   #7
Rovobay's Avatar
Rated Cap: 35
nice looking bus, let the fun begin!
My Build: http://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 03-27-2019, 11:50 PM   #8
Amen to that!!!
Old 04-04-2019, 09:18 PM   #9
Year: 2010
Coachwork: IC
Engine: MF DT466
Rated Cap: 81
A gov bus, looks straight and clean. Good find.
Miles O Roads is offline   Reply With Quote
