Old 11-21-2017, 08:10 PM   #1
Hello from Arlington TX
My wife and I have a 1982 Wayne's International that we are converting. I will have many questions about the bus it's self. I have no paper work, the engine is I don't know other than its a big block V8 converted to propane. I have an issue with the brakes, the hydrolic side works, however, the hydroboost side does not.
I look forward to picking the group collective.
Madelooney is offline   Reply With Quote
Old 11-22-2017, 06:17 AM   #2
Johnny Mullet's Avatar
Engine: T444E 7.3L
Welcome to the site!
Old 11-22-2017, 07:51 AM   #3
water boy's Avatar
Year: 1987
Engine: 7.3 IDI
Welcome! There are a lot of knowledgeable people here that can help you....
water boy is offline   Reply With Quote
Old 12-10-2017, 12:02 PM   #4
golfersmurf57's Avatar
Welcome to the group. If your booster isn't giving boost ,it's either not bled properly if its vacuum or no vacuum at the booster or bad. The hydraulic boosters run off the p/s pump and the engine must be running. There are a couple out their with air over hydraulic brakes but chevy didn't make any. If its hydraulic and the reservoir is full the steering should be screwing up as well which means bad pump. Also there out to be a buzzer sounding and a backup electric pump that should activate on demand.
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
