Old 12-09-2016, 10:55 AM   #1
Year: 1987
Coachwork: AmTran SS-22, 28 PASS
Chassis: INT NAVISTAR S-1753 "Schoolmaster"
Engine: 5.9L IDI, Allison AT 545, 5.57 Axle (I think)
Rated Cap: 28 Adult Passengers
Hello from Newark Ohio
Hello everyone....Newbie here.
I invite everyone that lives in Ohio and/or has a bus like mine/or similar to mine to add themselves to my friends list, and anyone else of coarse.
Yesterday, I bought a blue 1987 International Navistar S-1700 "Schoolmaster", more accurately model 1753 with a 6.9L IDI diesel engine, Allison AT545 4 speed automatic, 50,953 actual miles, AmTran model SS-22 (serial number 28541) 28 Adult PASS, (not to big or to small) with an auxiliary diesel engine and separate fuel tank that runs an A/C and alternator system. No rust anywhere, no dents or anything. It's an old Air Force bus. I think I got a very nice deal for $2,000.00 plus $145.00 county tax. Total $2,145.00.
I intend to make it into an R.V..
Any help from anyone would be very much appreciated.
Thanks everyone.
p.s., I drove it home yesterday and I don't remember busses being as slow or lacking power as mine was.
Well, that's something to talk about
MrPorterhouse is offline   Reply With Quote
Old 12-09-2016, 11:37 AM   #2
Chassis: International 1753
Engine: 6.9 International
Welcome
I have a similar bus, as does Famousinternetjesus.
My build is here, it's pretty basic.
http://www.skoolie.net/forums/f11/pr...llet-9266.html
I realize now that I haven't updated it in awhile. So I'll probably do that sometime soon as long as I don't forget.
Jesus did alot more to his as far as drivetrain upgrades. He added an auxiliary transmission, swapped in a manual transmission, and added a turbo kit. A lot of things that I would love to do if I used it frequently/lived in it full time.
You can find his thread here.
http://www.skoolie.net/forums/f11/19...bus-11642.html
I only use mine for a weekend get away type deal a few times a year so most of the stuff he did wouldn't be worth it for me.
Let us know if you have any questions.
Old 12-09-2016, 02:43 PM   #3
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
Are you on the Wolverine sight? And welcome from Cuyahoga Falls.
Thanks everyone.
Old 12-09-2016, 02:50 PM   #4
Year: 1987
Thank you
I'll be sure to check him out.
Old 12-09-2016, 02:52 PM   #5
Year: 1987
No, What is the Wolverine sight.
Old 12-09-2016, 10:24 PM   #6
Carytowncat's Avatar
That seems a great deal, congrats!
PS; This bus seemed super slow driving home for the first time, but after being filled with all my belongings it seems a whisker too fast and i tend to ease off the gas now. Perspective has changed a bit in the past six months.
Old 12-10-2016, 10:28 AM   #7
welcome!! from C-Bus here!!! Nice to see a fellow central ohioan!!
I have 2 busses, though they are not campers.. one is a Mobile DEV lab, the other is a daily driver (yep a grocery getter! and road trip machine)..
school busses can be slow, yours may be geared low if it came from ohio here as Many school routes in central ohio have zero freeway needed. . so many busses in this area were geared as to never need to run above 45-50 MPH.. its pretty easy to tell if you are dealing with a fuelscrew or spring governor, or if its gearing is the issue..
Old 12-11-2016, 02:06 PM   #8
What rpm are you turning in 4th gear? The 8.25x20 are a little shorter then my 10r22.5 but not 20 mph short. My bus runs the same gearing and I can go 70-75 after a few miles. Yeah it will slow down going up hills due to being redlined but it will maintain 50-55 mph pretty consistently.
I'd check the tv cable for your trans and make sure that is adjusted correctly. As far as top speed goes, I'd really need to know your rpm in order to tell you where to look.
Old 12-11-2016, 02:31 PM   #9
Cool!
Great to see another Air Force Bus on here!!!
Was yours an ambulance or a passenger bus? Edit: never understand, I see 28 passengers
Get us some pics
http://www.skoolie.net/forums/f13/im...now-14306.html
Old 12-12-2016, 03:21 AM   #10
When I got Dev it had 10r22.5 and 4.78 gears I maxxed at 64 running 2700-2800 rpm... now with 11r22.5 tires it goes 68 at that rpm.. with 5.77 gears I don't see a bus being able to reach 70+ unless it's revving way up there
Christopher
28 pass, 6.9l diesel, amtran, int navistar, s-1700 1753 schoolmaster
