Old 08-17-2016, 08:41 PM   #21
Carytowncat's Avatar
Beautiful!
I also have a GMC with the 366 big block.
I have a good friend who drives trucks, tractors, and dump trucks and he said if we keep new oil in the 366 will run forever.
I love the bbc motor because it is familiar to my mind. I have been working on V8 gas motors since i was young. I get them. First motor swap i helped with changed my life lol.
Congrats!
Old 08-18-2016, 08:30 PM   #22
Anyone know where the "fuse" panel would be in a 1974 chev blue bird?
Tootalltechie is offline   Reply With Quote
Old 08-19-2016, 06:36 PM   #23
Found my chassis fuse box. Is it just me or could there be a better place for it. While looking I found a "Weldon 7000" is there any use for it in a skoolie?
Old 08-20-2016, 08:00 PM   #24
Administration can this thread be moved to the conversion group?
Thanks
Old 08-25-2016, 07:46 PM   #25
Well today was busy...
Checked into getting a a second 50 gallon propane tank, now looking for a used tank.
Checked on getting an off the shelf "Y" pipe, no luck. Custom exhaust here we come.
Checked into getting 900 R 20 tires or something to fit, nothing. Custom rims and 22.5 tires down the road.
Old 08-25-2016, 08:55 PM   #26
Found out I have Allison Transmission AT 540 3 speed.
Old 08-26-2016, 10:13 PM   #27
Tootalltechie hi I'm from burns lake so although off your topic I'm wonder if you might know if you can put a wood cookstove in a bus conversion can't find a place where icbc says not allowed
Bluebird1998 is offline   Reply With Quote
Old 08-26-2016, 10:36 PM   #28
Hi Bluebird1998. If you are not using it as you drive I don't think there is anything they can say. Just install it like a mobile home. Also if you are using it for heat only you don't need a big one.
Old 08-26-2016, 10:40 PM   #29
I received a quote for tires and rims. Pick me up off the floor....wow is an understatement.
Old 08-26-2016, 10:43 PM   #30
Your tranny should be a 4 speed. The middle number in the 500 series Allisons is the number of gears.
Old 08-26-2016, 10:48 PM   #31
Tango, Thanks for info. I thought the gear selector showed the number "R N D 3 2 1"
Old 08-27-2016, 12:06 AM   #32
Pulled my "Y" pipe going to muffler shop in morning.
Old 08-27-2016, 06:03 AM   #33
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
That is four the D counts.
Old 08-27-2016, 12:07 PM   #34
Lol yup doh!
Old 09-18-2016, 08:53 AM   #35
Woke up today to ice on the bus 😣
