My guess is many people back out of insulating from underneath because of the difficulty and mess..
Well on my ER, if I insulated the undercarriage, I'd be covering up all my wires, shifter linkage, air lines, not to mention the undercarriage storage would have to get it twice, once in and once out. plus, if I put a mini split HP system on it, I'd have to make room for the parts under there as well.
I'll stick with a 10 or 12 inch roof raise, and put thermal barrier bubble sheets under my ply. I won't lose enough height to worry about.
BTW, I like your ride Kim, As far as installing roof vents, if you just want to vacate the heat from higher upinside, why not install a small duct with vents and a fan out the side or back to draw the heat out? maybe a 4" ducting with a 12 v computer fan?? (Just an idea...)
