Old 10-10-2018, 06:33 PM   #11
Originally Posted by sportyrick View Post
best engines out there are 5.9, 466, 7.3 and Duramax, avoid the V10 Ford
We all have different opinions. Personally, I think that the 8.3 belongs on the top of that list and also missing are the DT-530 & DT-360.
To be avoided: Anything newer than 2004.
Good transmissions :
MD-3060
2000series
MT-643 or 653
Less desirable transmission: AT-545
Good luck with your quest.
If you should find two DT powered 5 windows please let me know 'cause I want one of them
Old 10-15-2018, 05:59 PM   #12
Chassis: Ford E450 Van
Engine: 7.3
Rated Cap: 5 window / 29 person
MD-3060
2000series
MT-643 or 653
Hah I'll definitely let you know! Haven't found any DT powered 5 windows yet.
Thanks for the help, Steve. I've heard the DT-360 is good, just a smaller version of the 466 with better fuel mileage. What's your take on the DT-530? Haven't heard that one mentioned yet.
Chad1865 is offline   Reply With Quote
Old 10-15-2018, 07:30 PM   #13
Hey Chad,
The 530 is the same basic engine as the 466 but displacing 530 cu. in.
As best I understand it, many parts from the 466 & 530 will interchange. The big exceptions would be crank and rods.
Old 10-15-2018, 09:12 PM   #14
Originally Posted by Pizote View Post
Anecdotally, I have a 2009 Ford V10 and never had a problem with it. It's on a 14,4000lb chassis and pulls my 5000lb jeep around all day.
I have heard problems with the older V10's but it seems that mine is pretty solid.
My parents RV has a ford V10. Its reliable and powerful.
The downside is that its thirsty and repairs are expensive and a PITA especially in a van chassis.
Roll Your Own Build Thread
Old 10-15-2018, 09:13 PM   #15
I've got a 6 window with a high powered DT466E and allison 2000.
My 5 window has a Cat 3126 and allison 545.
Both are amazing buses.
You won't find a 530 in a short bus. But you could swap one fairly easily if you have the $$.
I'd take a shorty with a Cat 3126 any day.
Old 10-15-2018, 09:15 PM   #16
MD-3060
2000series
MT-643 or 653
The only short bus with an 8.3 was someone on here trolling us saying they had a 5 window with an 8.3. It never materialized!
Old 10-16-2018, 11:00 AM   #17
One is a 99 Thomas on a Freightliner chassis. Its a 5 window with a Cat 3126 and allison 545 with 4.11 rear end.
The other is an 04 IC CE300 with DT466 and Allison 2000. Its a 6 window.
They're short enough that they're not hard to drive and not too bad to park.
I am interesting...could u give more details information to me.
5504564@gmail.com thank u
liang2013 is offline   Reply With Quote
Old 10-16-2018, 04:03 PM   #18
I am interesting it? Where r you located?
Old 10-16-2018, 06:58 PM   #19
I have a DTA360. and its a great little engine in a shortie.. but like the cummins 5.9 it is a bit power lacking in a full size bus in the mountains.. well i say that nbecause it was mated toi an allison. 545.. it may be fine now that i have a 643.. i just finished the trans install and have yet to drive it..
the allison 1000 is another good transmission.. it is simlar to a 2000 but has even taller 6th gear than the 2000.. you'll find it on the IC BE series short busses and many of the GMC van chassis busses are sporting 1000's. it is a 5 speed up through 2005 and 6 speed capable afterwords..
Old 10-16-2018, 08:08 PM   #20
That 643 is PERFECT for your DT360.
If you ever tire of that bus I'd like first refusal!!!
