Old 09-13-2016, 06:43 PM   #21
oricha1984's Avatar
Engine: gasser probably
the A/C is pretty simple on those.. usually just a good cleaning of the coils all over inside and out, some new O-rings, evacuate and charge and be nice N cold... ive repaired a bunch of them over the years.. occasionally had to replace the ford compressor because they love to drop a vaslve plate and only pump on half the stroke...
I'll dig up information on the internet and try to figure it out myself. If not, I can always pay the local shop, but it will probably be 3x more expensive.
oricha1984 is offline   Reply With Quote
Old 09-13-2016, 07:09 PM   #22
Chassis: e450 super duty
Engine: 7.3l ford powerstroke
google > Split Systems-TransArctic. should be the first link to click on. I'm not sure how to attach pdf to here.
Blue Sky's
dopamine16 is offline   Reply With Quote
Old 09-13-2016, 08:11 PM   #23
GreyCoyote's Avatar
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
It's definitely a Ford. See here: Automotive Belts & Hose Vin Decoder | Gates Corporation
Your particular VIN (1FDWE45F9YHB5542 ) decodes as follows:
Manufacturer Ford Motor Company
Make Ford
Model Year
2000
Model Econoline (Super Duty)
Engine Series
V-8 7.3L
Engine Capacity V8, 7.3L - Turbo
Fuel Type Diesel
Vehicle Type Van
Country United States
So unless I'm milking without a bucket, that's basically a T444E, aka a 7.3 liter, which was a very reliable motor in the smaller busses and big pickup trucks. It's a workhorse. It's Ford's rebranding of an International design. And the mileage is basically nothing... just getting broken-in.
If they maintained this bus, kept it fed with clean oil, and there is no rust, that could be a very good deal.
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
GreyCoyote is offline   Reply With Quote
Old 09-13-2016, 08:41 PM   #24
oricha1984's Avatar
Thank you for the heads up brother.
Sent from my BLU LIFE ONE X using Tapatalk
Old 09-13-2016, 08:46 PM   #25
oricha1984's Avatar
Make Ford
Model Year
2000
Engine Series
V-8 7.3L
Fuel Type Diesel
Vehicle Type Van
Thank you for the info
I had researched the VIN# as well and verified that it was indeed a ford.
People in this forum have mentioned that the 7.3 is a good engine.
I spoke with a local diesel mechanic and he also mentioned the "not even broken yet" in reference to the mileage.
Let's just pray to the God of RUST to spare this one. Lol
