Old 11-13-2016, 06:43 AM   #1
Hey guys! New Skoolie
We have our bus and have gotten all the flooring up from the body. We've sanded all the rust spots and painted with rust stop. We are going to have an issue with the floor around the drivers seat because the gear shifter/transmission has bolts holding the cover down. We're stuck here because we don't want to damage any of the bolts holding the cover down. Any suggestions? This weekend we're getting all the rivets off the inside panels. Wish us luck!
hncordell is offline   Reply With Quote
Old 11-13-2016, 07:49 AM   #2
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
Welcome to Skoolie.net
Lots of WD40 or alike, wiggle back and forth, heat, impact wrench, if you break off the bolt, drill and retap threads. Unfortunately these buses are not fresh off the assembly line.
Tootalltechie is offline   Reply With Quote
Old 11-13-2016, 09:33 AM   #3
Carytowncat's Avatar
Welcome!
Where are you located, and may we see pictures of the bus please?
Old 11-13-2016, 09:45 AM   #4
Engine: Navistar 7.6L
Welcome!
Soak the bolts with PB Blaster, once a day for several days.
I prefer a 50/50 mix of acetone and automatic tranny fluid.
DoubleO7 is offline   Reply With Quote
Old 11-13-2016, 11:20 AM   #5
Yeah! I tried to add some to the post but it said upload failed. I'll try to add some. Our bus is a 1990 GMC with an 8.2 Detroit deisel. I believe 5 speed tranny. It was already used in some kind of conversion but they just used it for a fun bus not an actual living space. Much work to be done.
Old 11-13-2016, 11:30 AM   #6
Upload failed:(
I can't upload any pictures from my phone unfortunately. We have a Facebook- Living Happy 24/7, YouTube-Living Happy 24/7 and instagram-living_happy24.7 accounts if you guys want to see our progress so far.
Old 11-13-2016, 02:44 PM   #7
Welcome to the forum.
I think you have to have 5 posts b4 you can do the picture thing. 2 more, and I think you will be there.
Good Lucjk
1olfart is offline   Reply With Quote
