Old 11-22-2015, 12:48 AM   #1
Low594's Avatar
Chassis: Ford E-450 Super Duty
Engine: PowerStroke 7.3L Turbo Diesel
Rated Cap: 14,000 lbs
Hey there!
After thinking about this for a few months, I bought a short bus. I plan to turn it into a toy hauler for mostly dirtbikes. It will also haul our riding/camping gear and anything else to support our playtime.
Here's my dirtbike, 1998 Kawasaki KLX300R
And my big bike, 2008 Suzuki Vstrom 650
It's hard to be humble when you ride the short bus!
2002 Ford E450 SuperDuty 7.3L PSD Turbo 5window Shorty
Low594 is offline   Reply With Quote
Old 11-22-2015, 05:46 AM   #2
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Nice collection of machines you have there, man.
Old 11-24-2015, 01:02 AM   #3
Low594's Avatar
Thanks EastCoast!
Im trying to find out what I am required to do to drive my bus in Cali....
License & Reg are done.
What I am looking for is the Do & Donts, I keep hearing pieces from well intentioned friends, but cant find anything on it.
I relocated the top lenses, reds in the rear and ambers in front, but I was told they cant even function. Is that right?
I removed the Stop Sign, because I dont want it. But is it a requirement?
Now I am hearing that I have to paint it some other color than the yellow. Is this right?
I believe the "School Bus" decals have to be removed, which I would do regardless, but its nice to know.
What will I hear next?
Is there a sticky on state by state requirements somewhere that I am missing cause I am looking tooo hard??
Old 11-24-2015, 04:39 AM   #4
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Here are the NJ requirements. I know you're in Cali, but they might provide some guidance for you-
Originally Posted by NJ MVC
* Motor Home Vehicle Type = 05 Required Modifications
 Remove most seats from the bus : In order for the bus to be converted to an RV, the customer must make the following modifications to the vehicle:
Remove emergency lights including the side mounted stop sign
Repaint the exterior of the vehicle (Cannot remain any shade of yellow)
 Install a permanent bed or sleep sofa
 Install a permanent sink or bar sink (Must be in working order)
 Install a permanent stove or microwave
You might be able to get a way with red outboard, amber inboard on the back for high-mounted brake and turn, but it'd just be easier to plate over the front mounts, especially since they'll leak. If welding isn't something you're comfortable with, Tap Plastics does 4x4 samples that should fit over the mounting holes, or you can custom order.
Captain Obvious on deviantArt
Old 11-24-2015, 05:36 AM   #5
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I think Cali requires rainbow, day-glow paint jobs by law.
Old 11-30-2015, 01:15 AM   #6
Low594's Avatar
Thats a Frisco VC, I try to stay away from there!
Old 11-30-2015, 01:18 AM   #7
Low594's Avatar
I've decided the forward facing flashing lights are going away. I might put in 2 Marine type speakers for PA or Stereo use. I will be mounting off road lights up on the header. Paint is also happening soon.
