Old 05-02-2015, 03:12 PM   #11
Jolly Roger's Avatar
Engine: Detroit 8.2
The men at the bus barn here (nc) were not allowed allowed to make recommendation's on the book's but they told me that even if (after selling buses to there church) that I could adjust the governor's but I would burn up the rear end gear's? I cannot get any local's to recommend or do the work without handing just the gears to them? We want to be in texas from North Carolina now but the Jolly Roger can only do 49 mph downhill? I keep looking for complete rear changes but I also want to get away from split ring rim's? Any advice from your friend in texas would be great because this is where the Jolly Roger is heading even if I have to do 49 the entire way???
Old 05-02-2015, 03:24 PM   #12
Engine: 190hp 5.9 Cummins
None of that makes any sense at all. The rear end gears don't care how fast they are turning.
I would disregard most of what that guy told you. He lacks understanding of what he is talking about.
Old 05-02-2015, 03:30 PM   #13
Engine: Detroit 8.2
Ok I have 6.50 rear Gear's an at-545 with an 8.2 dd?
How do I get more road speed??
Old 05-02-2015, 04:02 PM   #14
Think about this:
I drove a 1962 Chevy "super duty" 1-1/2 ton 4x4 from elpaso to NE TN, it had 5:38 gears an Eaton reart, sb chebbie and 4spd....it was a 45/50 mph truck, I threw a 70 gallon tank off a 18wheeler in the bed, loaded bed and headed east.
It took 2-1/2 days to get to vidor Tx where I got stopped, by sheriff
A couple days later I was in Bristol TN....bet I got 4 miles to the gallon
Old 05-02-2015, 04:27 PM   #15
Engine: Detroit 8.2
Originally Posted by bansil View Post
Think about this:
Thank's for the history and I do appreciate the comment! But that didn't address the question?
Old 05-02-2015, 05:02 PM   #16
crazycal's Avatar
The answer isn't pretty. Probably best to start with another bus with the right drivetrain. Cheaper in the long run.
I'm hungry!
You Gotta Let Me Fly
Old 05-02-2015, 05:05 PM   #17
True depending on their final goal for the bus. The more parts you change one at a time, the more the cost go's up.
Or just swap out that old rear end for a nice, 4.44, or higher gear ratio.
Old 05-02-2015, 05:16 PM   #18
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
From what I understand the AT545 is a non overdrive transmission.
That is the first problem.
Second is the 6 something rear gears.
My bus does around 100 kph downhill (60 mph) with 4 something rear gears and a non overdrive transmission.
You can either exchange rear gears or replace the axel.
I feel like replacing the axel will be cheaper and easier than replacing the gears.
Most MD axels would fit I think. Possibly even HD axels.
Around here there are several MD and HD salvage places.
Hank's P-O-S is offline   Reply With Quote
Old 05-02-2015, 10:10 PM   #19
Speed, RPM's, gearing, tire size and MPG are all related. If you want to play "what if" with some numbers...spend a few minutes with them all on a decent calculator.
Like this one...I like the one at the bottom of the page...
Engine RPM Calculator
Old 05-03-2015, 05:39 AM   #20
Jolly, it just jogged my brain of what not enough gear does for a trip, I put on 37 inch tall tires to get a little more out of her
What size tires do you have?
