12-18-2018, 08:27 PM
#181
Coachwork: Never coached any teams, not even junior soccer
Chassis: I'm still figuring out what this means
Engine: CAT diesel
Rated Cap: No caps, only hats.
Originally Posted by Rivetboy
Now go on you tube and search for picking that Master lock.
Also, that lock and hasp is as only secure as the 3 carriage bolt heads on the left hasp that evaporate in less than a minute with a battery grinder.
This is known because I had the same setup on a storage container and it took me less than a minute to grind the carriage bolt heads off with a Dewalt battery grinder..
When the hasp was reinstalled allthread was welded into the hasp and ground flush so nothing to grind off to defeat it. That Master lock is still junk IMHO.
Good luck
Hmm, makes me think I should WELD these hasps in place, so it's more than mere bolts holding them in place. And better locks, which I've seen for this setup. Peace!
12-27-2018, 06:33 PM
#182
Engine: CAT diesel
Welding a DIY Back Step and Propane Tank Rack
As you might imagine, my main hopes for the new propane tank rack are that 1) the tanks never burst into flames and explode, and 2) the bottles never fall off and go rolling off down the highway.
12-27-2018, 06:58 PM
#183
That same battery grinder will go through that hasp arm just as fast it took on the carriage bolts. If they want to get it, they will get in.
12-27-2018, 07:03 PM
#184
Engine: CAT diesel
yep yep
I completely agree ... the easiest access is likely the many windows, any of which can be smashed in a second ... but I like to keep the low-risk, low-IQ burglars away
02-09-2019, 10:41 PM
#185
Engine: CAT diesel
Wireless Backup Camera Installed
Among other things, I managed to get the wireless backup camera running in the bus this week:
02-20-2019, 10:08 PM
#186
Engine: CAT diesel
Prison Bus Gets a Roof Deck / Cargo Rack
Full build video is on YouTubes. I see why people like the views up there ... what a nice feel to be on solid "ground" atop the bus.
02-21-2019, 05:50 AM
#187
Coachwork: Wayne Lifeguard
Hey, Spencer, your videos are great! Your build is coming along really nicely, and I've found your ideas inspiring. I think it was your flip-over bench that inspired me to build one. Best of luck and keep up the good work.
02-21-2019, 10:56 AM
#188
Engine: CAT diesel
Thanks! It's cool to hear that you made a similar bench! Woohoo
03-02-2019, 08:17 PM
#189
Engine: CAT diesel
Skinning Windows
In the end, I'm not sure if it was a good idea to skin a few windows in my bus with sheet metal. I mean, it wasn't necessary. But then, it helps obscure the works inside (a shower; some shelves).
04-09-2019, 03:14 PM
#190
Engine: CAT diesel
Sewing Cushion Covers on the Prison Bus
I'm not the best sewer/upholsterer, but it was a fun process:
04-09-2019, 04:06 PM
#191
Chassis: IH 3800, 8 window
Looks good, and undoubtedly smells better than the sewer/black tank...
12-25-2020, 09:54 AM
#192
Engine: CAT diesel
Hi all -- This bus conversion has been quite an experience. What I thought would take a few months ended up spooling off into years, and it became bigger and better than I'd ever imagined. Having built plenty of structures before, I still learned so, so much building out this bus. Here is a final tour video for y'all. The prison bus is moving on to a cool guy who will likely have a great time on board.
