Old 09-16-2019, 12:50 PM   #1
International DT466 Engine
Hello: I am on the verge of purchasing a 2007 Rear Engine bus with a DT466 engine and an AT3000 transmission. I am hearing that some have had problems with the DT466 engine - any insight you can offer about the engine will be helpful. Thanks in advance.
Begunahi is offline   Reply With Quote
Old 09-16-2019, 01:01 PM   #2
Welcome Begunahi,
If that bus were 4 years older I would get excited about it. By 2007 you are likely looking at EGR and DPF to add potential problems.
The medium duty diesels after 2003-2004 are equipped with emissions equipment that reduces reliability and increases maintenance costs.
There are some outfits that sell delete kits to remove the emissions equipment for off-road use. There may be some folks running them on the highway in the US. Be aware that doing so violates Federal law.
Old 09-16-2019, 01:30 PM   #3
Johnny Mullet's Avatar
Engine: T444E 7.3L
Out of all the emissions engines from 2004 to 2009 I encounter, the DT466 seems to have the least emissions related issues. They are still a very solid, dependable engine. I service about 4 of these regularly and they are all pushing 300K with no major issues.
Old 09-16-2019, 01:44 PM   #4
EGR was introduced in 2004... I dont believe DPF was introduced till into the Maxxforce DT years...
the DT466 when it changed ot Maxxforce DT for all new computers and went from a HEUI system to common rail system..
the 07 DT466 will have EGR, and that should be looked after but it was still bot the full-on emission Maxxforce DT..
Old 09-16-2019, 02:09 PM   #5
Welcome Begunahi,
Thank YOU very much for your thoughts. I will continue to look further into this before making my final decision. Again, I appreciate your time.
Old 09-16-2019, 02:13 PM   #6
Its good to hear of your experience with the DT466. I am learning there is no such thing as a perfect engine. I am not a diesel mechanic, so I am being cautious before I make my investment. Thanks again for your input.
Old 09-16-2019, 02:14 PM   #7
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
Welcome Begunahi,
My 07 IC was manufactured in 05 and has no DPF.
CMORGANSKOOL is offline   Reply With Quote
Old 09-16-2019, 02:14 PM   #8
Thank you for the information. It helps a lot.
Old 09-16-2019, 02:59 PM   #9
LOTS of problems with an 07 engine. Stay pre-04 for the best diesel engines.
Roll Your Own Build Thread
