Old 06-16-2019, 12:37 PM   #21
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Originally Posted by HazMatt View Post
Registered weight reads 23K lbs, and she scaled in at 16,280. Overall, no differentiation as to front/back, side/side...
thanks - useful information
Old 06-16-2019, 01:05 PM   #22
Chassis: IH
Originally Posted by Galleon View Post
Question: do these parts of the interior come out easily? They house the back of the front and back warning lights.
Not sure about on Thomas buses, but they weren't too bad on my Bluebird. I wrestled 'em out alone but it may be easier with 2 people. Edges may be sharp, use proper protection.
Old 08-09-2019, 10:23 PM   #23
Galleon's Avatar
Engine: T444e 7.3
Subfloor mostly in
Galleon is offline   Reply With Quote
Old 08-11-2019, 07:07 PM   #24
Galleon's Avatar
Engine: T444e 7.3
Framed
Old 08-13-2019, 01:47 PM   #25
Galleon's Avatar
Engine: T444e 7.3
answer: no. this portion also holds up a rear door support arm and should not be removed.
Old 08-13-2019, 01:57 PM   #26
Are you talking about the piece that abuts the ceiling (says "THOMAS" and "EMERGENCY EXIT" on it) or the piece that surrounds the square window?
Old 08-13-2019, 02:06 PM   #27
The front and rear caps are just screwed on(at least on my bus), There is nothing to removing them. The only door support is the extention rod that is held on by 2 screws at the top..
Old 08-13-2019, 02:06 PM   #28
Galleon's Avatar
Engine: T444e 7.3
the piece that abuts the ceiling (says "THOMAS" and "EMERGENCY EXIT" on it. i wanted to take it off to access the rear of the lights and the wiring in there. i could do it, but not easily
Old 08-13-2019, 02:10 PM   #29
Galleon's Avatar
Engine: T444e 7.3
i'll double check when i get home. i had the rear cap almost all off until i hit the door support extension rod, hidden from view in these pics, but directly under the "d" in "door" that looked to fix to the rear cap itself. maybe i could just unscrew it from the rear cap. i might just leave that rear cap in there, not sure.
Old 08-13-2019, 02:20 PM   #30
Yeah, I left those caps in place - it doesn't look like there's any rust behind them. I had also originally intended to leave the panels around the square windows in place, but they were actually concealing some pretty horrific rusted bits and had to come out. Are yours still in place or have you removed them?
Old 08-13-2019, 02:35 PM   #31
Galleon's Avatar
Engine: T444e 7.3
i left mine still in place. just checked out your build thread - man are you getting after it.
Old 08-13-2019, 02:39 PM   #32
I decided to treat rust as a personal insult.
Old 08-13-2019, 02:48 PM   #33
Galleon's Avatar
Engine: T444e 7.3
i had plenty but yours takes perseverance to the next level. just following your thread, i recommend corroseal. here's how my exterior paint job ended up
now on to more interior work. ceilings and walls come next, followed by floor and furniture.
Old 08-13-2019, 07:24 PM   #34
Took awhile to upload the pics. Removing them was easy as it is just screws on my bus, but there were a lot of screws. Remove 2 screws that hold the door extension arm and it come right down. Let me tell you it makes accessing wires in there a breeze. The only negative I see to removing mine is I have to find a neighbor to hold it up while I get screws started, it's large, and awkward.
Old 09-04-2019, 11:02 AM   #35
Galleon's Avatar
Engine: T444e 7.3
Old 09-07-2019, 09:24 PM   #36
Great job! What kind of floor and wall material are you using?
84chevyguyid is offline   Reply With Quote
Old 10-03-2019, 06:31 PM   #37
Galleon's Avatar
Engine: T444e 7.3
Floor is luxury vinyl planking in the wall material is a mishmash of pallets and old flooring
