Old 04-13-2019, 02:02 AM   #1
Location: The tops of mountains, the bottoms of valleys, and everywhere in between.
Chassis: international
Look a bus!
https://sfbay.craigslist.org/eby/cto...856690544.html
Iím looking for advice on this bus I really like the shape and size just wondering how reliable this could be and if the price is fair. The reason I like this is because is is as close to a flat nose in this length that I think exists.
HenrysCat is offline   Reply With Quote
Old 04-13-2019, 11:46 AM   #2
Sleddgracer's Avatar
Chassis: still looking for my bus
looks nice and clean - that nose would allow good visibility when driving
Old 04-13-2019, 12:59 PM   #3
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
If it was closer to me, the add would be down already...
Old 04-13-2019, 03:41 PM   #4
Diesel pusher, I don't think so. Must be a trunk under that dognose, or whatever you call those noses.
Old 04-13-2019, 06:25 PM   #5
geminusprime's Avatar
Chassis: Vista 3600
Engine: DT466E / AT545
The visibility of the 2nd Generation vistas are amazing. Flat nose may be a bit better, but in a pinch the vista is still better than the full dognoses I checked out and drove.
Can't even see the hood, you have to lean up a bit to see all 2 feet of it.
geminusprime is offline   Reply With Quote
Old 04-13-2019, 09:23 PM   #6
I like it. Mileage is good, 7.3s in a bus that size are just fine, the rear heat/AC is a bonus. For buses that length, I think its a reasonable price.
Old 04-13-2019, 10:02 PM   #7
Johnny Mullet's Avatar
Engine: T444E 7.3L
Looks like a decent bus.
Mullet's Thunder Bus Build
Old 04-19-2019, 11:30 AM   #8
Hey everyone! I went to see the bus today. I am looking for more advice now that I’ve seen the bus. If I like what I’m hearing, I’ll go buy it on Monday.
So first off, the instrument cluster is having issues. No fuel gauge, no speedometer, the temperature gauge read as hot as it could go, but the engine didn’t feel that hot, the odometer stopped as well.
I have the records of it’s last 3 inspections and it has only moved 1000 miles since.
The underside seemed to a bit oily, not sure of where the oil may be coming from. Any ideas?
It is a California bus so it has an exhaust regenerator installed which has a green indicator light that does not turn off with the key. It seems to be draining the battery relatively fast.
The seller is taking it to a diesel mechanic tomorrow to see what he can have fixed up for me prior to purchase, no extra charges added.
Old 04-19-2019, 12:05 PM   #9
Hey everyone! I went to see the bus today. I am looking for more advice now that Iíve seen the bus. If I like what Iím hearing, Iíll go buy it on Monday.
So first off, the instrument cluster is having issues. No fuel gauge, no speedometer, the temperature gauge read as hot as it could go, but the engine didnít feel that hot, the odometer stopped as well.
I have the records of itís last 3 inspections and it has only moved 1000 miles since.
Find out who the mechanic is and see if he'll go over the bus and find everything wrong with it.
Old 04-19-2019, 12:23 PM   #10
Instrument cluster issues are somewhat common. The most likely problem is cold solder joints on the circuit board.
I have seen quite a few that were repaired by simply resoldering the connections on the circuit board.
PNW_Steve is online now   Reply With Quote
