Old 04-22-2015, 05:47 PM   #11
Skunky Bus's Avatar
Chassis: Dodge S-600
Engine: 360 V8
Originally Posted by Knight Rat View Post
Gotta LOVE that old iron.! Even though just about every bus has something cool about it, there REALLY IS something extra special about the ones that wear classic sheet metal like that. My first one had a 1958 Dodge Power Wagon nose piece. OMG it was so ugly it was beautiful.!!
FYI: For anyone considering one of these beasts... And you're thinking it would cost too much to fix it up?? You WILL spend about the same money no matter what year it is. Why not save an old beauty queen while you're at it.??
I feel that way too. For example, all buses for sale can be divided into two categories: those that need new tires right away, and those that will need 'em later. And cheaping out on tires can have disastrous consequences.
If you really must have an RV that's cheap above all else, there's always plenty of S&S rigs out there.
Any action for which there is no logical explanation will be deemed "company policy."
- Akvol's Second Law of the Corporation
Skunky Bus is offline   Reply With Quote
Old 04-22-2015, 05:50 PM   #12
Engine: 190hp 5.9 Cummins
I vote mechanical Cummins. For the sake of simple, reliable, cost effective, low maintenance, ect.
IMO Gas engines aren't even worth the time to mess with them anymore.
Old 04-22-2015, 06:12 PM   #13
Skunky Bus's Avatar
Engine: 360 V8
Originally Posted by bluejeans View Post
i've enjoyed watching people's projects around here for a couple of years... thank you.
i've been wanting a bus but i had to be old and cute for my wife to even consider.. and I finally found it:
a 56 ford/superior b600. not in such bad shape either. just missing the motor. no broken glass. only one window removed for a chimney at one point.
i went to look at it but was still on the fence until he told me his price... $500. sold!....
still haven't decided exactly how i want to build this... i do have an extra nv4500 trans and was thinking to put in a cummins. wife is excited to be my minion for sanding and bodywork (i'll probably just sandblast the entire body...
...this will be a gradual project. better to take our time and make it what we want than try move in too soon and never finish. i'm guessing it'll take a couple of years at least.
Nice find, Bluejeans! Sometimes we're in the right place at the right time.
Ever wonder if some things are meant to be? I waited a long time to find an old Dodge with either a Wayne or Superior body; eventually the opportunity to buy one practically fell into my lap.
I've thought about getting a Cummins for mine too. (Good tip, Tango). My bus will be drivable with just some minor repairs; its gas Mopar V8 is in my mechanical comfort zone, but info from other Skoolies tells me that it'll take to petrol like a sot to liquor.
Old 04-23-2015, 12:13 PM   #14
If you do decide to go the Cummins route...keep your eye out for one of the older,"Two Wire" (one hot + one ground) motors and avoid the later computerized units. They are great engines but...anything that relies on computers to run is well...like...going to the moon in something built by Microsoft. Risky and expensive business. As a result, the newer motors can be bought cheaper than the old ones. Why?...'cause people who've done their homework just don't want'em.
You can also get a 6BT for less money than a 4BT. That is mainly a function of supply & demand. There are tons of 6BT's around. Either will serve you far better than any gas guzzler. And the only real difference between the two is the number of cylinders. Nearly all parts are interchangeable and plentyful. The six weighs in at about a thousand pounds, has a few more horses and feet of torque and gets a little less mpg. The four weighs about 750 and can be had in stock form from 80 horses up to 130 (what I have) with about 330 pounds of torque. Plenty to pull a small bus if geared right. And with just minor tweaking, it is safe & easy to get 250 hp out of a four. There are some sled pullers getting around a thousand out of the same four banger, but at the expense of only lasting for a pull or two. Pretty amazing little motors that when set up properly are good for a half-million trouble free miles between recons.
Am I believer...well, ya. You might say that.
PS...they can also be tuned and geared to get an easy 25mpg even in something like a small bus. A few people are even claiming 30.
Old 04-23-2015, 12:43 PM   #15
bread trucks have 4bt in some of them, stay away from non T type
Old 04-23-2015, 01:30 PM   #16
And...when looking, make sure any engine you consider was an "over the road" type and NOT a stationary...like pumps, generators and such. They can be converted but the cost is prohibitive in nearly all cases. Also preferred is the P7100 inline injection pump. There are some rotary pumps still out there but are a PITA to dial in/tune.
With a serial number, you can go to the Cummins site and get a history of nearly every engine they have built in the past few decades. Very handy to verify how it was originally configured and any factory recon work will show up as well.
And while it likely of no interest other than for specificity...I just remembered the 4BT was also avail down to 55 hp.
Old 04-23-2015, 02:13 PM   #17
Wow, that 4bt should last forever at 55hp.
Old 04-24-2015, 09:05 AM   #18
Definitely longer than the 1000+ monsters. Still amazes me what can be done with these little four bangers. And many of the mods up to about 500hp involve nothing more than injector tweaking and adding another turbo. Upgraded head studs are a good idea too but it can be done in a weekend. Nuts!
Me...I'm going the other direction. MPG and reliability. Plenty of hp & grunt just the Cummins built it.
Old 04-25-2015, 01:15 AM   #19
Year: 1956
Coachwork: superior
Chassis: b600
I'm familiar with the 4bt. To me the bummer is that there's so much hype around this engine ( granted, its amazing) that prices for one are not often reasonable. I have a 6bt 12v and am happy with and with one in my bus I'd never have to worry about the bus getting too heavy.
Nat, I agree; diesel is the only way to go unless you plan on the bus never leaving your back yard.
bluejeans is offline   Reply With Quote
Old 04-25-2015, 09:45 AM   #20
Ya...the Super Hero hype has definitely driven up the prices on the older 4BT's. They make the 6's look like a bargain if you have the room for one. I didn't.
