Old 04-25-2018, 02:56 PM   #1
Tryonis's Avatar
Chassis: TC2000 RE
Lurking
Been lurking for a while, going to look at a bus tomorrow near me. Had a few questions regarding this bus in particular. First if i decide to buy the bus it needs batteries. What can i throw in there just to get it home? Second it has had the outer rear wheels removed so its sitting on singles in the rear, can i limp it home that way (about 30 miles) or do i need to get some used wheels and tires to slap on it? Probably a dumb question but I don't know whats legal or not.
Thanks
Tryonis is offline   Reply With Quote
Old 04-25-2018, 02:59 PM   #2
Originally Posted by Tryonis View Post
Been lurking for a while, going to look at a bus tomorrow near me. Had a few questions regarding this bus in particular. First if i decide to buy the bus it needs batteries. What can i throw in there just to get it home? Second it has had the outer rear wheels removed so its sitting on singles in the rear, can i limp it home that way (about 30 miles) or do i need to get some used wheels in tires to slap on it? Probably a dumb question but I don't know whats legal or not.
Thanks
Sounds like a borderline "parts bus" from that description. If it isn't in amazing shape I'd probably pass.
Any decent 12v battery should start it.
Roll Your Own Build Thread
Old 04-25-2018, 03:08 PM   #3
Tryonis's Avatar
Chassis: TC2000 RE
I asked the maintenance lead guy and he said all that has been removed is batts, tires and flasher lights. Of course i will know more tomorrow. I scheduled a day off to really give it a once over inside and out. It has a 8.3 cummins and a Allison 3060 which i am looking for. It supposedly runs with a boost charge so we shall see. I don't even know if i can test drive it with rear singles.
Old 04-25-2018, 03:31 PM   #4
The singles will be ok. Not for long term, but short term low speeds should be ok. Check their condition and pressure.
Old 04-25-2018, 03:59 PM   #5
Tryonis's Avatar
Chassis: TC2000 RE
Thanks for replying, so you think i can test drive it or actually get it 30 miles home on singles?
Old 04-25-2018, 04:08 PM   #6
If the singles aren't dry rotted to hell and they're properly inflated I'd go for it if the rest of the bus is NICE.
You know its got a great engine trans combo. But eye everything on it with a lot of scrutiny.
Good luck, and have fun!!!!!!
Old 04-25-2018, 04:48 PM   #7
Tryonis's Avatar
Chassis: TC2000 RE
I will! Its kinda scary to think of driving the bus for the first time in traffic, kinda like when i bought my first Harley 90 miles from my house and had to drive it home never having driven a street bike before. Thank you again for the advice!
Old 04-25-2018, 06:54 PM   #8
Chassis: Saf-T-Liner MVP ER
You can drive it with singles on the rear.
You will probably be close to the load index of the tires, but that's okay.
The reason for duals is to cope with the rear axle at full axle weight ... in my case around 24000 lb. The actual unladen weight on my rear axle is 12400.
I think most full size buses have similar numbers ... I too have your drivetrain, rear engine.
Steve Bracken
Build Thread
Old 04-25-2018, 07:31 PM   #9
My first FAST bike was a ZRX1200. Bought it 200+ miles from home. FUN ride back though.
Old 04-25-2018, 07:33 PM   #10
Tryonis's Avatar
Chassis: TC2000 RE
well ok then ill drive it home like that if i can slow and steady, im digging this bus based on the drive train based on what i have read from all of you guys and i really appreciate all of the insight yall have dropped from what i have read.
Old 04-27-2018, 02:53 AM   #11
Running on singles for 30 miles shouldn't be a problem as long as all of the lug nuts are there and that they are on tight.
Proper inflation is going to be very important as well.
While any 12-volt battery might work, since you are going to be needing a battery it wouldn't be a bad idea to get a proper sized battery. Yes they are a lot more expensive than a little one but a starter on a diesel engine takes a LOT of juice to turn.
Old 04-27-2018, 09:35 PM   #12
Tryonis's Avatar
Chassis: TC2000 RE
Well that is a good thing because i won the auction! Now i got to get it home.
Old 04-27-2018, 10:49 PM   #13
30 miles is nothing!
My last bus came all the way from north of Houston to Apopka Fl. At 50 mph the whole way!
Congrats and show us pics of this beast!
Old 04-27-2018, 10:51 PM   #14
Yup. Mine came 500 miles. Others have gone much further.
If it's a diesel, and it's running, the chances of not making it home are low.
Steve Bracken
Build Thread
Old 04-27-2018, 10:55 PM   #15
Absolutely.
My 98 shorty had 200k++ miles and 16k hours on it and still made the 1800 mile trip home with no issues at all.
Old 04-27-2018, 11:38 PM   #16
Tryonis's Avatar
Chassis: TC2000 RE
I will post some pics once i go get it. Still can't believe i just won a bus.
Old 04-28-2018, 11:14 AM   #17
maybe when you pick it up you can talk nicely to the school lot and get them to toss a set of outers on it.. sometimes they do things liek that for people.
Old 04-30-2018, 03:48 PM   #18
Tryonis's Avatar
Chassis: TC2000 RE
Ok well the plan is to get up at the crack of dawn tomorrow and go pick up the bus. I have a big ol AGM tractor battery charging right now and hope its enough to crank her. Wish me luck!
Old 04-30-2018, 04:07 PM   #19
A regular old car battery will get it started usually, unless its a BIG, tired old engine.
You'll be fine with that tractor battery!
Old 04-30-2018, 04:38 PM   #20
Tryonis's Avatar
Chassis: TC2000 RE
Been sitting a year but we got it turned over with a booster when i went to go look at it last week and i checked all the fluids and etc. Maybe i should bring a can of starter fluid just in case. I know i am probably over thinking this but i want to be prepared as much as possible. Honestly im more worried about not taking out other cars when making turns, LOL.
