Old 08-16-2016, 05:45 PM   #1
Mounting generators
Anyone have any thoughts on mounting a generator on the front of a bus??
pandaconda is offline   Reply With Quote
Old 08-17-2016, 01:19 PM   #2
Rated Cap: 40 Prisoners
The original Bluebird Wanderlodge had a slide out of the front of the bus
and a three piece bumper to allow the generator to slide forward out the
front of the bus, usually hydraulic powered. The space between the frame
rails is 33" and the height is 24" and the depth or length is around 50".
Old 08-17-2016, 04:51 PM   #3
NowhereFast's Avatar
Chassis: Carpenter
Engine: d466 mechanical
Seen it done a few times. Lots of food trucks mount their generators on the front as well
Nowhere Fast - Sarasota, Florida
NowhereFast is offline   Reply With Quote
Old 08-17-2016, 06:25 PM   #4
I'm researching generators right now.
If you mount one on the front, I would make it removable that way no one steals it and you can put it away somewhere
x225x is offline   Reply With Quote
generators
