11-21-2016, 10:17 AM
Need advice!!
Hello everyone! My name is Matt, I'm new to this forum.
My girlfriend and I have been looking for a vehicle that we can convert into a tiny home and tour the States.
This vehicle won't only be used for our trip, we would like to be able to live in it while we are not traveling.
My question is I've been looking at so many different busses and engine/transmission options, body styles, rear end ratios, etc. I'm sure like most of you were in the beginning, I'm starting to get overwhelmed.
To add to the anxiousness of this situation, my girlfriend and I just re-couped from taking a $2k loss on an RV we bought last year. I want to buy the perfect bus because this is going to be our home, but I want to take my time and make sure I am informed and know exactly what I am looking for.
At first we wanted a short bus with a handicap lift for the extra width, but the short bus we were looking at required a CDL. So with further thinking we decided we may be better off going with a mid sized bus since we needed a CDL anyway. This would allow me (6'5") to actually be able to stand up straight and not hit my head, and provide us with a more comfortable living area.
I was wondering what busses should I be looking for? I really want something with a DT466. Do they make mid sized busses with DT466's? And if so would any of these models have a handicap lift? Also what transmission should I be looking for?
I know I probably sound like a noob, but that's because I am lmao. Thank you for all your future help
11-21-2016, 11:14 AM
Check with your state, but almost all don't require a CDL for an RV, regardless of it's size or air brakes or not.
So you need to get the bus titles as an RV then you're good regardless of size.
The DT and 545/645 trans are in older buses..to me that's anything over 10 or 12 years..but I drive a bus and practically no school district here keeps them beyond that. Many reasons for that - the local school contract requires us to buy 2.5 new buses a year, the fleet is 22 buses..so nothing is over 10 years old. Another big congtractor here changes half his fleet every 2 years - so NOTHING is over 4 years old.
And yes, these 2005 buses go for 4-6k. Allison 3000 is what we have for transmissions and they do no break. maybe a speed sensor or something, but not the trans.
CAT's are expensive (parts). cummins common as are the dt466.
Why do you want a handicap lift? Width? AFAIK all buses are the same width give or take a few inches. And few if any big buses have the lifts.
Buses come in many lenghts/capacities..i drive a mix of 66, 72 and 76 passenger buses, mostly convention but we do have a BB transit (for now..it goes bye bye in june). I may tell my boss to list it here - 135k miles and always garage kept, new rad and many new air system parts in the past month. I'm tempted...
google 'school bus types' and read up a bit.
With your height you'll probably want a taller bus (they make them..not too common) or else raise the roof.
An alternative would be to get a former city transit (not geared for hiway usually) or a OTR coach - the ideal as they are the biggest, tallest and have basements (think prevost). More miles on them (by far) for teh same price though.
11-21-2016, 11:36 AM
Everyone one of us are noobs. With a bus you will learn everyday. Save another $2k or more buy reading every thread you can find here. Free knowledge for the reading. Knowledge is power in this hobby. Ignorancey in this hobby can and will be costly.
11-21-2016, 12:08 PM
Absolutely good advice!
You can do sooo much with a bus - from 'fancy tent' to full out high end RV.
Making a plan, and gathering the knowledge to do it and learn from others, um, mistakes, i mean, experiences, is well worth it!
Go to RV shows and dealers and look at how the 'pros' solved problems, where they put things (like tanks, panels, etc) is helpful too.
11-21-2016, 12:47 PM
At 6'5" your selection may be slimmed down pretty seriously unless you are comfortable with raising the roof. I know that there are 78" headroom buses around but of all of the buses that I have looked only a handful of them were that tall. Even with a 78" factory ceiling you will loose some if you insulate well.
As far as I can tell all of the Bluebird A3's (All american 3rd generation?) are 78" headroom. Somebody please correct me if I am mistaken?
As far as power train goes, there are numerous threads here comparing engines and transmissions. Read up and you will get a goo education
Prof.fate gives some good advice.
CAT=Expensive to service.
Cummins 5.9 & International T444 - Very good in a smaller bus. Perhaps a bit under powered in a full size. These are "dry liner" motors built very much like a car engine in that to rebuild them you pull the engine out and bore the cylinders & replace part etc.
International T444. Service and parts are readily available.
Cummins 8.3 & International DT466 - Great motors in any bus (IMHO). More displacement means more horsepower and torque. More fun to drive and you are not flogging the motor constantly. That gives you better reliability and (generally) better fuel economy. These are "wet sleeve" motors which means that a rebuild can be done "in-frame". You don't have to pull the motor. You replace the cylinder liners, bearings and other parts with the motor in the bus.
Earlier versions of all of the above motors (Except maybe T444?) came with mechanical fuel injection. No computer. The electronic motors generally will make more HP and get a little better fuel mileage. The mechanical motors are simpler. Less to break and cheaper/easier to work on.
As far as transmissions go you will likely see mostly Allison's:
AT545 - 4 speed. No overdrive and no lockup torque converter. Not very desireable.
MT-643/647 - 4 speed. No overdrive but it does have a lockup converter and will handle more power than the 545
2000/3000 Series - 6 speed. BUT most buses have them configured as a 5 speed. As a 6 speed they have two overdrives as a 5 speed they have one. They also have lockup torque converters. This group would include the MD-3060. That is the one I would recommend you looking for.
A mechanical DT466 and an MD-3060 in a low miles West Coast bus would be a dream.
Good luck on your quest!!
S.
11-21-2016, 01:25 PM
11-21-2016, 01:30 PM
Thank you everyone for your responses!
I have been doing a lot of research recently, including driving an hour to the closest bus dealership and spending 5 hours looking at different buses.
I'm not that picky about head clearance, being 6' 5" I am used to hitting my head on things so I am more tolerant, however when I was checking buses out in person there was one bus that I stood up in perfect, and it wasn't a full-size (That's a plus for me) I am not sure though if it is a type-b or a short type-c (If they even make those?) Like: Bus Sales New Used, School Buses Commercial Church Bus Airport Shuttles Limo Buses Wheelchair Vans all on Sale! and Bus Sales New Used, School Buses Commercial Church Bus Airport Shuttles Limo Buses Wheelchair Vans all on Sale! I read in a different thread on this forum that type-b buses aren't worth converting, so should I stay away from these? Is it possible to have a type-c this size?
I am looking for the smallest bus possible while still maintaining reliability, and live-able space. I would like to have the DT466 and MD-3060.
Also A handi-cap lift is preferred because we would like a second door, but will not have access to the back latch door because my motorcycle will be mounted on a hitch platform, blocking use of the door.
11-21-2016, 01:31 PM
Chassis: Mini Bird (8 window)
Rated Cap: 24 +1
Hi Matt, welcome to the forum! My boyfriend and are currently traveling the country in our 2000 Bluebird Mini-bird. Our trip has been amazing - I know how overwhelming it seems but so worth it.
Our bus has a T444E and I'm ashamed to admit I still don't know what tranny. We bought our bus for $2500, put another $1500 into the conversion and then spent $4500 at the repair shop to get the bus ready for our trip. I'd say spending more money initially will save you in repairs. Tires are expensive lol.
Our bus made it over the Smoky Mountains (4 mile 7% grade was tough but we did it). I'm not sure it would make the Rockies though. Top speed is 65 but we cruise at about 58 - don't want to push it.
You will fall in love with your bus. Remember to take it one step at a time, you'll get there!
11-21-2016, 03:35 PM
Look at previous conversions. You can rip out the interior and start over with the previously installed tanks etc. Saving thousands and lot's of time. Quite often you can find a bus that someone built as a monument to themselves. Nothing wrong with that until they go to sell it. Return will be low for them. Know your stuff and be ready to strike. Getting your hands on a DT466 with a MD3060 is doable but they go quick. These bus's are like old people they need daily care and the condition can change in an instance and the prescriptions can be very expensive. But around hear they are like gold to owners. All these things are is Just a big truck with a very big 6 cylinder engine. Don't jump to buy.
My 5.9 s a bit doggy on the bottom but it will run easy 75mph@ 2550 RPM The tranny is really the 643.
11-21-2016, 05:52 PM
Hey Matt,
Whoever told you that conventional buses are not worth converting is full of something. They have advantages and disadvantages just like any other style.
A flat nose front engine bus will be more maneuverable and have more living space than a conventional of the same overall length.
The conventional will be quieter and easier to work on the engine. If you spend a lot of time on the road the "quieter" part can be a big deal.
In the shorter buses I don't think that you will see rear engined buses.
I just bought a Bluebird rear engine 40' bus with a Cummins 8.3 and an Allison MD-3060. It was a "last minute" bid as I had started bidding on a conventional with a DT466 and Allison 2000 but lost that auction. The RE was my backup. I would have been tickled to have gotten the conventional.
Look around at the conversions here. You will see many fine conversions of conventional buses.
the bus in the link you provided looks like it could be a good candidate for conversion. Mileage/condition would be BIG questions. The asking price is what I would consider reasonable if it is a low miles well maintained bus. If it is a 200k mile bus with rough spots then I would suggest that you keep looking.
11-21-2016, 06:10 PM
Year: 2005
Engine: Detroit MBE906
I'll second Steve on this..... while a conventional is not my personal preference (I have a RE transit style bus), many people successfully convert conventionals and they make perfectly acceptable living/camping quarters. I could see myself buying and converting one if that one "too good to pass up" deal were to come along. Mechanical condition and engine/drivetrain combo should be first and foremost on your mind when shopping, with amount/degree of rust a very close second. Anything beyond that is strictly personal preference.
Assuming the same engine and transmission in both.... if I had the choice between a transit style that was questionable in mechanics or had too much rust, or a mechanically sound conventional with no (or very little) rust, I'd pick the conventional every time, and adapt my design to work with it.
11-21-2016, 07:20 PM
11-21-2016, 07:26 PM
Amen brother AlleyCat!
That is my mindset. I much prefer a rear engine bus but when I saw a DT466/Allison 2000 equipped conventional that looked like it was going to go cheap I was all over it. Less than 100k miles and the bidding sat low right up to the end of the auction. It wound up going for more than I could justify but I would have been thrilled if I had landed that one.
11-21-2016, 07:48 PM
Year: 2005
I don't know, I'm a little leery of anything where I am not allowed to start it up and test drive it, even if it's no more than a lap or two around the parking lot. Could be a way to hide a problem that they don't want to admit to.
11-21-2016, 08:16 PM
I've seen quite a few of those and they're pretty much beat on. Rode hard and put up wet.
11-21-2016, 11:45 PM
I have said this before and I will say it again, there is no one bus that is prefect for every application. That is why there are four different types of buses with various lengths, seating configurations, and power packages. Different states have different minimum spe'c's that are much higher than other state minimum spe'c's which can tend to make them more expensive as a used bus.
For instance, every Type 'C' and Type 'D' bus built for service in CA or WA must have at least one emergency door on the driver's side in addition to the rear emergency door/exit. And on Type 'D' RE buses there needs to be an additional side emergency door on the curb side.
Of the two buses you highlighted I would choose the newer bus for several reasons. - The newer bus has a better power package
- The newer bus has 12" windows so it will have a higher ceiling than the older bus that has 9" windows.
- The newer bus has the same standard sized tires and wheels on the front and rear axle. The older bus has a lift and it may have a flat floor which would explain the smaller wheels and tires on the drive axle.
- The newer bus has deeper skirts which makes it easier to hide any of the systems under the floor. Making tanks so you can't see them doesn't make them better but visually it can make a completed bus look less like a school bus.
The only caveat is don't purchase anything that has any sort of rust. Out here on the left coast bad rust is described as the frame rails no longer being shiny black. My B-I-L in MI describes not bad rust as holes you can't read the newspaper through.
Always, always, always spend the $$$ up front to get the bus that will do the job best for you. The cost of repowering and re-gearing can cost 2X-10X the original purchase price.
Many times the 12- and 13-row Type 'C' buses will be considerably less expensive than a 5- or 6-row Type 'C' bus with the same power package, mileage, and condition--it is the most common of all buses made and they make about 100 of them for every Type 'D' bus or 5- or 6-row Type 'C' bus.
Good luck and happy trails to you.
11-22-2016, 07:40 AM
You guys and gals are amazing thank you so much for all the help!
11-22-2016, 07:48 AM
Most likely a 545 TRANSMISSION.
