Old 04-23-2015, 02:18 PM   #21
tyndrgn's Avatar
Send a message via Yahoo to tyndrgn
Nas_ster, Could not find any leaks, the slave seems to be full, I do not understand what you mean by power shift into other gears? Thanks EastCost every little thing helps.
tyndrgn is offline   Reply With Quote
Old 04-23-2015, 02:20 PM   #22
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I never did hear what their problem was, but these folks had a very similar experience to yours. I'm going to try pm'ing them.
http://www.skoolie.net/forums/f34/we...our-10517.html
Old 04-23-2015, 02:27 PM   #23
Coachwork: IC
Chassis: CE300
Rated Cap: 32
BTW I pm'ed you my email address if you'd like me to upload the pics for you.
Old 04-23-2015, 03:16 PM   #24
how was it shifting before? any grinding? and going up hills under a load was engine revving more than moving forward?(clutch slipping) I exploded a clutch disc once and it went from driving to nothing quick.
hopefully they can come up with something
Old 04-23-2015, 03:26 PM   #25
tyndrgn's Avatar
Was not grinding, was not slipping, up hill the rpm would drop slightly but kept on going
Old 04-23-2015, 03:30 PM   #26
good to hear if it goes into gear while engine is running the clutch is released atleast, now when you let clutch out it wont engage, it could be a stuck throwout bearing, wounder if there is an inspection cover with a grease fitting, might be able to see location of bearing
Old 04-23-2015, 03:50 PM   #27
tyndrgn's Avatar
Bansil that's some hope at least, EastCoast emailed you pix, if it does not go through let me know may have to do it straight from phone
Old 04-23-2015, 04:05 PM   #28
Engine: 190hp 5.9 Cummins
Power shifting is shifting while rolling without using the clutch. You have to match the engine rpm to the speed your traveling to get the gears to line up enough to slip into gear.
All standard trans I have ever seen have a inspection cover. If it's a stuck throwout bearing, it can stick with the clutch engaged, or disengaged. The tree truck last year was stuck engaged, therefore it was always in gear. So I power shifted it to drive it home.
If yours is stuck in the disengaged position, I would crawl under the bus with the bus shut off. Use a pry bar through the inspection hole to manually force the clutch disk forward to it makes contact with the pressure plate again.
Then jump in the bus, stick it in first, and don't touch the clutch. Try to start the bus. It should jump forward as soon as the starter starts spinning. Then start driving and power shift your way home.
Throwout bearings are like everything else. They sit to long they sometimes stick. They live in a vary harsh environment under there. Oil, mud, water, and clutch disk material gum them up.
Old 04-23-2015, 04:10 PM   #29
SAFETY if under bus always have brakes set and a couple chocks one in front and one in back of tires is good cheap quick insurance
Old 04-23-2015, 04:13 PM   #30
tyndrgn's Avatar
Sounds like a plan let me see what I can find out on that
bluebird, broke, clutch, stuck
