Old 03-12-2016, 08:35 PM   #1
Chassis: international
New and so lost
Hello, I am new here and to the whole skoolie world. looking for info on a "shore line" and on the install of an inverter with a toggle switch to charge "standard" batteries and then the batteries to power everything else (fridge, t.v and such) any forums or threads that would help that you can direct me to would be appreciated! thanks!
karma8282 is offline   Reply With Quote
Old 03-12-2016, 09:44 PM   #2
Robin97396's Avatar
Hello, welcome and you're in the right place. You'll find threads on your listed subjects and so much more. Lots of solar info here too.
Old 03-22-2016, 11:26 PM   #3
Year: ntyt
Coachwork: Trying to find a bus
Chassis: Need to figure that out
Engine: more information needed
Send a message via Skype™ to VOMbooWOP
this is my first post
what is your energy source to charge the batteries? how and how often are you planning on using the fridge, tv and such? how much time daily is your energy source going to be providing how much consistent energy to charge the batteries? what are the battery specs?
I am no professional, but knowing this information would help understand what you are asking. I dont have information on a shore line specifically, but
thesolarplanner.com is a site that i found extremely helpful when sizing my PV array, inverter and batteries. Configuration is going to vary from application to application.
wholesalesolar.com is another site I found helpful. They have pre-made off-grid/grid tied "kits" essentially that are designed to be compatible and tested etc. You can size your systems' needs, and compare it to something similar.
There's an abundance of information there, I hope this helps!
VOMbooWOP is offline   Reply With Quote
Old 03-23-2016, 02:46 PM   #4
Thanks, this is actually when I first came on here. I have learned alot since then. I actually have a schematic of sorts I'm looking for in put on just go to my page with my pictures if u care to put ur opinion in. Thanks again!
