04-27-2019, 12:35 PM
New Guy To This Site
Hello Folks.
I'd like some input on my idea to turn a bus into a tow vehicle. We are currently using a "2000" F-350 dually to tow a restored Army vehicle to parades and shows. Towing about 10K.
I would like to find a bus to convert into a tow/camper vehicle. The towing is most important with the camping being secondary. I'm thinking bus because of the door & step arrangement. We have Family members with disabilities. A bus makes more sense than a toterhome for my needs.
What I want to do is shorten the bus body to end right behind the rear axle. I do not want all the overhang I see on most busses. Again, my overnight needs are secondary to my towing needs.
Have any of you shortened a bus body??? Are there any busses around with a standard shift tranny anymore? I do not care if it's gas or diesel but I do not want a computer on the engine. Now, how bad have I limited my options?
All input is welcome. Trucker~Tim Thank you in advance.
04-27-2019, 12:42 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Originally Posted by Trucker~Tim
Hello Folks.
a standard transmission seems to be quite common on Canadian buses - not so much, I'm told, on buses in the US - "Kijiji" is one site to check out, especially the 3 western provinces
04-27-2019, 12:58 PM
Chassis: IH
There are a few manual buses around. For non-computerized you'll have to go back a few years ... since *most* will be automatics, you might consider a trans swap. Find one with a dead AT545 for practically nothing and swap in a 5-speed (or whatever, really.)
The gassers towing a heavy load will struggle up any hill, and drink the gas while doing it. Skip the T444/7.3 engine (adequate for light buses, underpowered for a full size bus towing 10K) and look for DT466 or 8.3 Cummins. Cat engines aren't bad either. Really, any automatic other than the AT545 will do alright for towing (that said, I have a 5 speed in mine).
04-27-2019, 02:31 PM
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
I don't know why shortening a bus would be that difficult.If one was careful during the dismantle it seems to me the rearmost section could be removed as a section and reinstalled as a section once the main portion of the body was sectioned to your desired length.I have not seen it done but went out and looked at our BB and it looks doable. Gene
04-27-2019, 05:25 PM
There are a number of buses on this site that removed the back cap, removed sections of walls and roof and reattached the cap leaving an 8'-10' flat bed. Some have kept the roof on and had a covered porch. They are here, search and ye shall find.
04-28-2019, 06:05 AM
Thank You All!
Lots of intel to digest. Going to be a while and a lot of research but we will get there soon enough. Thank you all. I'll start digging thru the archives.
04-28-2019, 10:24 AM
Coachwork: Thomas / international
Engine: Dt 360/ spicer 5 speed
Rated Cap: 42
I have a dt360 and a 5 speed and it really isn't enough gears to tow anything serious. If you can't pull a hill in 4th, the gap between 3 and 4tb is huge and will slow you down to a Max speed of 40mph.. at least in my 28' international. A bigger engine would help forsure, but I think,with 4 gears and two lockups, an Alison 643 would likelly perform the same or better and more like a 6speed with a variable 3 and 5th gear. A lot less to think about when navigating city streets too. Just my 2˘ based off my experience.
Love my 5speed but it sure ain't no road ranger.
04-28-2019, 11:47 AM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
yes you can have what you want
A matter of time, mostly. Many buses I have looked at, up close and personal, you can detach the rear end cap, remove a section of body, then reattach the end cap. Most older buses, seem to have been built in 2ft panel sections. some of the newer ones seem to have panels, with 4ft sections. My 1954 wayne school bus was available to be shipped in flat panels and pieces to be assembled later, like be shipped to Australia then assembled. I have seen bodies shortened and frame left longer, and frame and body shortened. Shortened buses with bumper hitches, and or fifth wheel etc. There are few manual transmission built since the early nineties. Manual transmission seems to have gone the way of passenger cars. They are out there. I dont see a good reason why a non computer engined bus cant be converted to manual trans mission. I see used transmission parts for medium duty trucks for around $1500-$2000 that are complete you might call a conversion kit, have pedals and such to go with them too. buses for sale from up to the mid 1980's have a reasonable probability of being non computer and manual transmission.
william,
04-28-2019, 12:19 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
william,
there are quite a few school buses for sale in Canada equipped with manual transmissions - especially in the western provinces
04-29-2019, 10:52 AM
Thanks Again Crew!
I think now my focus will be on finding the bus I want with the motor and gearbox I want. The nice part on this deal, I'm not in a big hurry. I'll let "that right bus" find me so to speak. Kool!
Tim & Lori Powell
"All that is necessary for the triumph of evil
is that good men do nothing."
05-03-2019, 12:00 AM
Spicer 5 speed will do - if ratio between 3rd and 4th is an issue - you can usually go up or down one size on the tire (9R22.5 to 10R22.5, 11r22.5 to 10R22.5) without issue to get that sweetspot where you want it. Even low HP diesels (170HP or so will usually have 450+lbs/ft of torque.
I am seriously considering shortening/bobbing a fullsize bus. Compared to cutting out a dented roof of a passenger car, cutting out a clean roof of a donor vehicle, welding it in place... cutting out 2 to 8 feet from a fullsize bus & reattaching the rear section seems pretty easy. I intend on visiting national parks and doing some hunting and fishing from a skookie and that 8 to 10 foot rear overhang seems troublesome. Seems like cutting out 8 feet and towing a soft-top Jeep would produce a similar overall weight, only add about 4 feet of total length, and allow for a nice runabout to hit local downtown museums/attractions. Unless I find a nice 6 to 8 window shorty with midsize truck cab, I am likely to 'bob' a fullsize for towing.
05-03-2019, 05:44 AM
Thanks For The Reply.
I'm not worried about speed. We live in the Midwest so mountains aren't an issue. We'll find the right fit.
Tim & Lori Powell
05-03-2019, 06:43 AM
That IDI 6.9 you're wanting is only around 330 lbs/ft.
05-16-2019, 12:15 PM
Shortening the distance between the rear bumper and the rear suspension is not very difficult if the engine is not behind the rear axle.
Your problem is going to be the power package. The vast majority of school buses spend 95% of their service life on routes at speeds less than 35 MPH. It is rare to find a bus that has the power and gearing to go highway speeds. Add on 10K hitched on behind and you will be living in the slow lane all the time.
Most big HP buses are rear engine buses. But there have been a few buses with engines up front that had big HP engines. I have seen a few BB AA's that had Cummins 6CT/ISC engines and some Type 'C' buses with big HP DT466's.
You will want to find a bus with an engine with at least 250 HP. Anything less will mean slow speeds for you.
Good luck!
05-21-2019, 09:42 AM
Hey Crew.
I'm only looking at front engine buses. As far as speed, when we tow the Military vehicle we never run over 50 mph if even that.
My biggest worry is trying to "bob" the back end in my shop. Just don't know if it's something I can do by myself. Not sure who to even call to have it done?
Tim & Lori Powell
