Old 12-20-2017, 09:31 AM   #1
Year: 1982
Coachwork: Ward
Chassis: Ford E350
Rated Cap: 16
new member from Munich, Germany
Hello all,
Just joined a few days ago and started reading. Will take many more days to get an overview...
I live in Munich, Germany but the Skoolie I will build is on the West Coast. It is a Cutaway, so a lot of compromises will have to be made, but it will need to be my little home for only some days every couple of weeks or months.
Doing a lot of thinking about the floor plan, not a tons of options in a small bus, but still. Specifically start to think how I can make the door for the wheel chair lift anything positive.
Horst
Horst is offline   Reply With Quote
Old 12-20-2017, 10:08 AM   #2
Robin97396's Avatar
Welcome Horst
You've come to the right place. There's a number of people here that have crammed an amazing amount of house into a shorty or cutaway bus.
That lift door is a big help when putting something large into your bus. The rubber seal can be replaced if it's leaking. Just try carrying a wood stove through the service door.
You've already got your bus, so where is the transformation going to take place?
Robin
Nobody's Business
Old 12-20-2017, 03:33 PM   #3
Year: 1982
Coachwork: Ward
Chassis: Ford E350
Rated Cap: 16
That lift door would take away a lot of space if I would use it as a regular second door. I am still thinking about a clever way of using it instead of just making sure it is sealing tight and forgetting about it. I have not seen any other builds using such a door smartly but I will keep reading.
The build itself will happen where the bus sits now, Central Coast of CA...
