Old 04-27-2015, 11:29 AM   #11
It looks like a great low budget build!
I particularly like the turquoise kitchen appliances. They look like the whole unit was taken out of a '60's or '70's vintage RV.
As far as sealing the dog house and transmission cover, butyl tape is one of the best to do the job--take them off, lay a line of tape along the edge, and then screw it back down.
As far as sealing the windshield, it depends upon where it is leaking--is it leaking because the gasket is allowing water to leak betweeen the glass and the rubber or between the rubber and the metal? If you want to do a quick and dirty job of it get some butyl rubber caulk and apply it all the way around the gasket making sure it covers both the glass and metal side of the gasket. The best way is to determine where exactly the leak is occurring. It may not even be the windshield but something higher up in the front cap.
Old 04-27-2015, 12:37 PM   #12
Originally Posted by crazycal View Post
Right click, select copy image location, click picture tab above, paste url, done.
No right click on a phone.
05Willys is offline   Reply With Quote
Old 04-27-2015, 12:42 PM   #13
I am also not sure where the leak is coming from yet. I was driving in the rain and snow for a few hours before a drip ran down the inside of the windshield.
Thanks for the tip on the butyl tape. I will go grab some.
Old 04-27-2015, 01:00 PM   #14
I use the photobucket app to upload images and it'll give you the IMG handle you need to post to forums.
Loving the shorty. Definitely the route I plan to go.
jawa01 is offline   Reply With Quote
Old 04-27-2015, 07:09 PM   #15
If it took some time for the leak to appear on the inside of the windshield it is more likely the leak is coming from some place other than the seal around the glass.
Look upstream for the culprit. Check all of the lights and all of the seams around the front cap. It doesn't take much of an opening to cause water to dribble down.
If you end up taking the lights off to check them for the leak reinstall with a little butyl tape.
Old 05-11-2015, 02:43 PM   #16
love the color and style of your of your kitchen.... where did you get it??? i want one!
miss_rockford is offline   Reply With Quote
