Old 12-05-2016, 09:48 PM   #1
Sasquatters's Avatar
Coachwork: Thomas EF
Newbies in PA!
So we just flew to Florida and drove home our bus! It was an adventure in itself! Now we are back and just starting to get to work on the conversion.
We brought home a 27 foot 2003 Thomas EF with a 3126 Caterpillar engine and AD 2000 Allison Transmission. Got us the full 1000 miles without any issues to speak of.
We know we are in for a lot of hard work to complete this. It's only day two for us and already we are tired and sore. It will all be worth it in the end!
Right off the bat, with our bus being wheelchair accessible, we've run into issues with removing the track seating rails. If anyone has any ideas or tips for removal please let us know. I've heard of one person that removed them via drilling but apparently we haven't found the right drill bit for the job or something! Tomorrow is another day and we will try again though!
Sasquatters is offline   Reply With Quote
Old 12-05-2016, 10:37 PM   #2
Carytowncat's Avatar
Welcome, and good luck!
Btw a member here has a sister who went full hulk smash on her seats to remove the stubborn ones. lol I get a kick out of that.
Old 12-05-2016, 10:55 PM   #3
Haha! Sounds like she had some fun doing that! Though for us the seats are t the problem, they came out easy. These are the rails that we are having a time with.
Our Blog | Facebook | Instagram
Old 12-05-2016, 11:18 PM   #4
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
Is that bolt heads I spy next to the ends of the rails? Maybe unbolt or cut those and try again.... if that fails I'd be willing to bet they're bolted on from underneath.... I'd get down there and check into that next.
Old 12-06-2016, 09:31 AM   #5
That bolt you are seeing is what was holding the wood down. These rails have bolts every 4 inches. They are bolted from underneath as you suspected. Unfortunately only half of them you can reach from underneath and the other half are stripped. Luckily I found a video a guy made on here that explains the drill bit he used to just drill them out from the inside! So that's our next step!
Old 12-08-2016, 03:48 PM   #6
Coachwork: BB
Engine: Cummins
Rated Cap: 25.999K
drillbits
Most drillbits that you can buy at an average hardware store are absolute junk, the bolts will kill them quickly. The best way to get them is with a carbide center-drill, then use a carbide ball-endmill to drill down into the bolt shank. Carbide stuff is expensive, if you know of any machine shops, they might give you some old ones. To do this with some home-depot Cobalt thing is going to make a long day unless you are only talking a few bolts.... Good luck, and welcome to the coolest site on the web!
SDR76 is offline   Reply With Quote
Old 12-08-2016, 08:26 PM   #7
Engine: Navistar 7.6L
If those rails are installed like mine...they are flat head allen bolts.
Hard as diamonds and drill bits do not like cutting into them.
The hex key hole tends to break the edge off of the drill bit really easily.
DoubleO7 is offline   Reply With Quote
Old 12-08-2016, 08:36 PM   #8
Thanks so much for the info! We will try out what you mentioned and see what happens!
Old 12-08-2016, 08:37 PM   #9
Yeah we've been breaking almost everything we try. Did you eventually get yours out? If so what worked for you?
Old 12-09-2016, 11:59 AM   #10
prof.fate's Avatar
when things get tough a gas wrench, sometimes called a hot wrench, can work wonders.
prof.fate is offline   Reply With Quote
