Old 05-05-2019, 08:41 PM   #1
Overwhelmed Newbie
We are picking up our 2004 Thomas saf-t-liner EF tomorrow! The first items on our to-do list are demo and painting exterior. Iíve searched the group for painting tips, but Iím still a little confused. Here are my questions:
1. Do we need to thin our paint (rustoleum)?
2. Will we need to sand the whole bus? If so, what grit?
3. Many talk about washing the paint with TSP or acetone or just dish soap. Is it necessary to use the chemicals or is dish soap enough?
4. We will need to remove the stop sign and arm. What do you use to patch the holes with?
5. Will any paper/newspaper work to tape up the windows and bumpers?
6. How many gallons did you need to cover your bus? Mine is 40 passenger.
Any other helpful info you want to share would be great! We are not painters so Iím a little nervous for this process.
CC08 is offline   Reply With Quote
Old 05-05-2019, 09:07 PM   #2
Galleon's Avatar
Engine: T444e 7.3
There is much to do, but the journey of a thousand miles begins with a single step. Demo itself is several full days.
There is a thread you can read on painting
http://www.skoolie.net/forums/f10/pa...a-bus-524.html
Many advise this particularly if you are spraying
Yes-120/200?
Probably dish soap is fine
Bondo, silicon caulk, construction adhesive, epoxy, fiberglass etc
Sure
Several gallons?
Galleon is offline   Reply With Quote
Old 05-05-2019, 09:16 PM   #3
Sleddgracer's Avatar
Chassis: still looking for my bus
this will save you hours and hours and hours masking your bus - I use the paper masking with the masking tool - - -
Old 05-05-2019, 09:26 PM   #4
Ey, we don't need no stinking safety guard!!!!
Old 05-05-2019, 09:30 PM   #5
Yes-120/200?
Sure
Several gallons?
Thank you for your reply!
Old 05-05-2019, 09:31 PM   #6
Wow, very interesting! Iím going to look up this product now. Thank you
Old 05-05-2019, 09:34 PM   #7
somebody using that hand taper will finish taping the bus while someone without a hand taper fools with the windshield using newspaper - coming from a professional painter
Old 05-05-2019, 09:36 PM   #8
for the windows, go with the rolls of paper - on a bus, use 12" paper
