Old 07-05-2019, 05:04 PM   #1
Oxygen
Hello my name is Larry, my wife and I have been dreaming about traveling the US in a schoolie. But I have to sleep with oxygen and a bipap. My question is can i get enough power from a generator and/or solar panels to run all night?
Thank you looking forward to hearing your thoughts.
Lroberts5572 is offline   Reply With Quote
Old 07-05-2019, 05:25 PM   #2
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
A cpap/bipap can definitely be ran all night from battery. If you include a humidifier, the total draw is greater but still possible. It's all about sizing your battery bank. Many of these devices will run directly off 12VDC so you don't even need to run them via your inverter.
I'm not sure what the oxygen portion of your question means so can't respond to that.
JD - Full timer out west
My Adventures & Build
Old 07-05-2019, 05:31 PM   #3
HazMatt's Avatar
Chassis: IH 3800, 8 window
Welcome, Larry.
As my rock farming Yankee Gramps would say,
"Ha'ad tellin', not knowin'."
This question has been previously answered, in the positive, as I recollect.
But I can't say, not knowin' what it's power requirements are to get you thru the night.
If you don't know, there's a relatively inexpensive gizmo called Kil-A-Watt that can tell you fairly precisely what energy the CPAP consumes during a session.
Old 07-05-2019, 06:08 PM   #4
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
A CPAP or BiPAP will not kill the batteries unless they are underpowered. For example my two 1500 CCA on-board batteries wouldn't even know they were hooked up to my BiPAP. I've been on camping trips where a marine deep cycle battery was more than enough power to sleep comfortably through the night. My advice is to add a battery or two if you're unsure to the bank on the bus and not to worry after that.
Remember Tim Allen's line?
M1031A1 is offline   Reply With Quote
